Question about Blueant Blue Ant 093732 X3 Micro Bluetooth Headset - Hot Pink Wireless Headset
BlueAnt X3 Mic Problem!!!
BlueAnt X3 has worked for 4 weeks with no problems on iPhone but now I can only hear conversation but can't transmit conversation (nobody can hear me on other end) tried same Ant X3 on another brand cell phone and mic works fine but wont on iPhone. Please Help!!!
dlisee2005@sbcglobal.net
  • 49 Answers
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Posted on Apr 09, 2010
No phone dectected
reset the device. turn it off, press and hold the volume plus and the green button until you hear a siren. turn off the st3 and turn it back on. choose the language desired then search for devices using your phone
Jan 12, 2013 | Blueant Supertooth 3 Bluetooth Handsfree...
Two Way Audio Problems
Unfortunately, yes, that is normal for simplex operation. The actual phone link, if cellphone, is often simplex. and you're attempting to use an additional simplex device on top of the cellphone's. Full-duplex requires a separate transmit and receive frequency pair for each end of the conversation, or link..
The way analog phones and many radio services get around this is by using "repeaters". These receive on one channel and transmit on another) for each conversation. When the two separate devices (your cellphone and the Bluetooth headset you're using) are combined, and with both needing it's own TX/RX pair), the effects you described are multiplied by two.
Mar 22, 2017 | Universal BlueAnt Q2 Bluetooth Headset -...
Can't pair blueant bluetooth with iphone 4s
Open the device's microphone, ensue it is NOT on charge, hold the answer button and the silver flat button (hidden by mic when closed) and it should work
Nov 29, 2011 | Blueant Blue Ant 091193 Supertooth II...
Cant connect to iphone 4
Did you put the device into pair mode before hand? To do this with the device off hold the green button until you hear a language loop, when you hear the language of your choice immediatly let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, at that point go to settings/general/bluetooth on your iphone and the ST3 should show up click on it and repair-reconnect. If it does not show up in the bluetooth menu then power off your iphone then power it back on. I have heard this issue a few times since Apple released OS 4.2. There does not seem to be a easy solution if a power cycle does not fix the issue. The only way I have been able to fix this problem is to restore the firmware on the unit through Itunes as Apple as usual released a firmware which causes more problems that features it implements... Sigh
Dec 26, 2010 | Blueant Supertooth 3
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Dec 04, 2010 | Blueant Z9 Wireless Headset
I have the mini bluetooth 2.1 usb micro adapter. The device works with my keyboard & mouse & can see my blueant head phones but the music will not tranfer to the headphones it just plays with the...
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Oct 07, 2009 | IOGear (GBU211) Bluetooth Wireless Adapter
Wont sync with iphone
Make sure that the headset and the phone are both are in "pairing" mode. Even though the iPhone's bluetooth is on you will have to select the headset from the phones bluetooth menu. To get the headset into pairing mode press and hold the "+" sign for 3 seconds. Hope this Helps!
Jun 08, 2009 | Apple iPhone 3G
Conversation?
Hello Thesilent1,
The other guest, has hit a very good point have you tried checking your mic? If not try changing it out. If you still have a problem do this; get a power meter and connect it to your antenna jack of the CB and the other end of the meter to the antenna this will put the meter in series with the CB and the antenna. then try to key the mic and speak, if the meter indicates 4watts PEP then the transmit function is working and you are getting out. The second test is to set an RF generator to 27.185MHz at -123 dbm or 5.1x-16 watts and use a 1kHz tone to modulate the signal, couple the signal to the antenna with an insulated wire loop and this will allow you to test if you can receive signal. These two tests will show if you can transmit and receive. I believe the problem is with your mic, but I have provided two tests that will prove if you can transmit and receive, so you are ready to test. Let me know how it goes.
Thank you,
Shuttle83
Oct 31, 2008 | Midland 1001Z 40-Channels Base CB Radio
Iphone 3g mic
hardware seems broken. If it was a software problem, then the bluetooth would not have worked as well
Aug 13, 2008 | Apple iPhone 3G
BlueAnt Bluetooth
hello lilgator
here's your manual from here BlueAnt X3 micro
riz.
Apr 25, 2008 | Blueant Blue Ant 091022 X3 Micro Bluetooth...
Blueant Blue Ant 093732 X3 Micro Bluetooth Headset - Hot Pink Wireless Headset Logo
284 people viewed this question
Top Blueant Radio Communications Experts
Josh Whitehead
Josh Whitehead
Michael Vincent Cruz
aliasger yq
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
