Question about Dell Axim X3 Pocket PC
Amim 30I My Axim died literately over night. I turned it off went to bed and the next day it would not turn on. Any ideas on how to fix it or a cost to repair it.
  • Dell Master
  • 13,433 Answers
Have you tryed, a reset and a hard reset?
Try contacting dell.
If dell is no use, try asking from a local pc repair shop.
Its possible that the device has got a hardware issue and the mainboard might need to be replaced possibly high price. around the price of a new one I guess.
Posted on Feb 11, 2008
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
The sound on my Magnavox CD130MW9 stopped working
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 21, 2012 | Televison & Video
I have a model 36fx48b 1998 hitachi that simply stopped turning on. we watched it last night and turned it off to go to bed then the next day when we wanted to watch it it wouldnt turn on...instead it...
Only serviceman can repaired that problem, It depend on the damage spare parts but usually the labor cost is uniform or fix. The spare parts makes it high in price. lets hope that this part will not be hard to find nowadays. But technician can substitute the part if he is competence. Probably your problem would be power supply or H-out
Aug 15, 2011 | Hitachi 36FX48B 36" TV
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Phone doesn't turn on.
You should not allow the battery to fully drain,it will die sooner.
Remove the battery for 5mins, replace,and then try and turn on the phone.
Apr 07, 2009 | Motorola Mobility RAZR V3
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Dell Axim X3 Pocket PC Logo
44 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
