Question about Amana ACS7270AS Electric Kitchen Range
Have f 3 error
After self cleaning oven now have F3 error message what can be done dont have much money and fairly mechanically inclined fixed dryer 2 weeks ago need help bad
  • john_hen_iii Feb 04, 2008
    it would help if i could understand what is written
Sorry try to unplug it ok then see if u can get it open if not wait 1 2 min plug back in see if error resets itself ok thx nick
Posted on Feb 04, 2008
    Master:
    Sergeant:
  • 440 Answers
Try unp;ug hole unit for min see open then hit it hard over then plug back in cheaka gain if i can wile its off
  • nick helpap
    nick helpap Feb 04, 2008
    that was be the guest sighned in wrong sumtimes this site is screwy
F3 beeping in self cleaning mode
Hello Jane, thank you for allowing me to assist you!
If you are getting an error code F3, it is commonly referred to a faulty sensor probe or a wiring harness between the sensor probe and EOC (electronic oven control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC on the range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Nov 17, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My oven shows a f9-3 code how can i fix this short of calling a repair person
The F9-3 error code means that their is a problem self clean door lock system. Typically their is 2 switches that check the position of the door latch and even if it's open and not in self clean mode the switches are telling the computer the latch is closed. You should if fairly mechanically inclined be albe to find the latch behind the control panel and use the wiring diagram there and check those switches using a meter set to a low ohms setting and check for one switch being open (infinate ohms resistiance) and the other to be closed (zero ohms)
Good luck, i hope this helps
Gene
Jul 31, 2011 | Jenn-Air JJW8530C Expressions Collection...
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
Hi
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Lower oven message E3, E0, F3
on maytag's a F3 means shorted or open oven temperature sensor. google your models oven number codes.
Jun 22, 2010 | Ovens
Roper oven B9757X0 Did a self-cleaning. When finished fan was still running. Error message F3. Turned breaker on & off. When try to use fan kicks on, but not off.
The F3 error code indicates a fault with the Oven Temperature Sensor (RTD) being Open. The soultion is to replace oven temperature sensor (RTD). Also check the wiring harness to the sensor for damage.
Oct 18, 2009 | Ovens
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Amana ACS7270AS Electric Kitchen Range Logo
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
