Question about Sylvania SSD803 DVD Player/VCR
Dvd will not play some times
Some times when i put a dvd in to play ( the movie will start breaking up or when you hit play you can motor on the infrared trying to move then about a minut or so a messag will come up and say problems with disk can`t read please remove disk) they are disk from block busters.
  • Anonymous Mar 27, 2014
    DVD Played Just Fine One Day then the same disk would not play the next day and gave compatibaly error
    Master:
    Sergeant:
  • 440 Answers
Try disk cleaner 1st ok bud
Posted on Feb 04, 2008
  • nick helpap
    nick helpap Feb 04, 2008
    lens cleaner cd i ment
Sony dvd player error t99
Hi Nemegraff,
I have a Sony DVP- NC665P dvd player. I burned a dvd movie and noticed I could not play it on my player. I was getting a display code "T99". I believe the "T" stands for time on the dvd.
Anyway, to my surprise, I found out if I press the "top menu" button on my remote, the dvd will start from the movie's main menu screen....then just hit enter or play and the movie will play. My problem is solved. I hope this helps you.
best,
larry
Oct 17, 2012 | Sony DVP-NS575P DVD Player
Disc play interrupted
I recomend that you clean the lens to see if that makes a difference.
Also you might want to look at my Tip on dealing with DVD's that jump.
Apr 05, 2010 | Mintek DVD-2580 DVD Player
Ps3 wont play movies
Sounds Like your blu-ray drive is going bad. if you still have warranty play movies until it breaks and get a new one
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Wont play dvd jensen vm9311
You can bypass all that. Here's how:
This will work without having to do anything to the pink wire - just tape it and leave it alone. But the next time you unhook your battery cable you will have to put the code in again.
Put in DVD
When the blue screen comes up, hit STOP twice on the remote
punch in 1,2,6, and 4
hit DOWN 1 time
hit PLAY/ENTER (although you can't see it, this turns off the parking brake bypass security feature)
**at this point the display became visible and you will now see the menu which makes it much easier.
hit DOWN one more time to change macrovision
hit PLAY/ENTER
hit SYS SETUP twice to save and exit menu
From now on, you can just put in a movie and it'll start - no more grounding or toggle switch procedure, and you don't have to use the e-brake.
Oct 22, 2008 | Jensen VM9510 Car DVD Player
Daytex tv/dvd combo..Dvd won't play movies.
have you tried cleaning the disc you are wanting to play
Sep 04, 2008 | Televison & Video
Jensen dvd receiver model#vm9311ts
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jun 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Dvd will not play movies
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
Oct 20, 2007 | Disney 13" TV
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
MY SAMSUNG DVD+VIDEO COMBO V4600
What you're describing is a common problem for this particular unit, a bad spindle motor. In some cases the motor can be removed by the tech and torn down for cleaning.. But in a high percentage of cases shops just replace the motor... What's happening, as your symptom appears the spindle motor is beginning to spin irratically. In turn the picture can sometimes just drop out. In others it simply folds over and is unwatchable. The spindle motor is not too expensive.. Good Luck Bill
Jun 10, 2007 | Samsung DVD-V4600 DVD Player/VCR
Magnavox DVD player mwd200f
I would start by replacing the cable from the DVD player to the TV, sounds like a break in the cable, or the plugs are dirty, also, just a precaution, use a CD cleaner.
May 08, 2007 | Philips Magnavox DVD Player MWD200F
Sylvania SSD803 DVD Player/VCR Logo
79 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
