Question about Linksys Wireless-G Broadband Router
Router of linksys
Hi guys, i have been facing a problem with my wireless setting.I still can see the signal on my receiver, but the internet still goes down. i tried to make repair, but it did not work. it tells me that the computer can not changer your IP address. any suggestions
    Master:
    Sergeant:
  • 440 Answers
Try latest drivers on all ok and move it up higher then unplug it for 20 min then back in from ac ok hit reset botton on back
Posted on Feb 04, 2008
The router often looses wi-fi signal and dhcp gives wrong address ( exemple: 169.164.....)
Here are some links for things to look for and check for you wireless connection isues:
If the links do not work just copy and past them in to you browser. If you dont have a internet connection available I have listed them below the links.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=172c1dae41534ddd818c560b60c7c230_4029.xml&pid=96&slnid=16
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=efc03a44a5bb47bd804cf4d0eb3015c8_Top_Causes_of_Intermittent_Wireless_Connection_to_a_Linksys_.xml&pid=96&slnid=16
Top Causes of Intermittent Wireless Connection to a Linksys Router
There are three key reasons that may be cited why the wireless connection between your Linksys router and your computer is intermittent or is experiencing timeouts.
i. You have a low signal quality received from your wireless router.
ii. You are experiencing signal interference from other wireless devices.
iii. Your router's firmware needs to be upgraded.
You have a low signal quality received from your Linksys wireless router.
The location of your wireless router with respect to your computer greatly influences your connection to the wireless network. For a better signal quality, it is ideal that the wireless router is placed in a central spot of your house or on a location free from any obstruction blocking its range.
To determine the signal quality received from your wireless router, you must connect to the wireless network first.
NOTE: For instructions on how to connect wirelessly to your Linksys router, click here. If you're using a Mac computer, click here.
Once connected, check the signal strength received by your wireless adapter or Airport for Mac users. The recommended signal strength should be closest to full bars to have the best connection possible.
The frequency used by your router's wireless network may be 2.4 GHz, 5GHz or both. Some devices may also be using the same frequency and this causes the interference to the wireless network of your Linksys router. The most common examples are cordless phones, microwave ovens and baby monitors. Another possibility of frequency interference is that there may be other wireless networks in the area. Your frequencies may be conflicting with each other.
To solve this, turn off the device that is possibly causing the interference or relocate your router away from it. Another solution is to change the current wireless network channel which is set in your router's settings. For instructions on how to do this, click here.
If you are having unstable connection and have confirmed that the previous causes are irrelevant, then you may have to upgrade your Linksys router's firmware. For instructions on how to do this, click here.
Encountering Intermittent Wireless Connections Using a Router
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
    Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
  • Customizing Wireless Settings of the Router
    Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
    1)To change the router's SSID or the wireless network's name, click here.
    2)To change the router's channel, click here.
    3)To enable the wireless security on the router, click here.
    NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
Dec 14, 2010 | Linksys WRT120N Router
Receiving wireless signal but unable to connect to the Internet
you have to set your router into mixed.....and set your gateway into LAN & WIRELESS...
Jul 08, 2010 | Linksys Cable Modem
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Hey guys could i use my router as a radio to pull the internet signal from a next router without using any cable
With the Linksys router it is not possible. You will need to connect the cable between the two routers. Linksys router will not pick up the wireless signal from the other wireless router.
May be it will work If you upgrade the DD-WRT Firmware. Not sure but it may. consult with the DD-WRT expert before upgrading the firmware.
Apr 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G2.4 GHz Broadband that my laptop doesnn't recog
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
If that doesn't work then upgrade the firmware of the router.
Firmware is the software of the router. After upgrading the firmware, it is recommended that you should reset the router and reconfigure the router.
Click Here to know more about router and network
Feb 13, 2010 | Linksys Wireless-G Broadband Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Getting a router signal, but no internet
Have you check if you have a valid IP address? You could run IPconfig in the DOS window to verify this. If you have a valid IP address, try pinging the default gateway (You should be able to ping it.) Then, try to ping a website. If you could ping a website or URL but still can't browse check your firewall settings and optimize your browser.
Please post here what happen.
Thanks and regards,
BeHar
Jan 18, 2009 | Linksys (WRT54GC) Router
Hi Ive connected my linksys wrt 54g working fine on main puter but can't connect on my laptop .It's showing strong reception but then says cannot connect,Thanks,Guy
Check in the router settings, in your internet browser from your deskyop, type 192.168.1.1 and enter the router config screen by using a blank username, and admin for a password. Look through the settings and make sure it is set to wireless signal on. Also, look to make sure your laptop isn't made specifically for Wireless N technology. Some wireless adapters aren't backwards compatable.
Mar 14, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
