I have a Hotpoint HTR16ABSARWW Top Freezer Refrigerator in my garage. With the cold weather we are having in Atlanta, the freezer has turned off. What do I need to do?
Re: I have a HTR16ABSARWW Top Freezer Refrigerator in
You need to warm up the garage for it to work right. The cold control reads the refrigerator temperature and if it's already cold, will not turn on the compressor. Hence the freezer warms up to the ambient temperature.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
yes the cold weather can effect the proper operation of the fridge they make a garge kit for these unit that can be baugh separatly and installed to help this problem
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Most refrigerator Manufactures have tested these machines in hot and cold weather and weather will effect operation and electricity consuption.
As far as cold weather goes It would run much better in cold weather than hot. As far as it being in the garage : It will wear on it faster. The humidity is not good on them and they get more dirt through the system and will need its normal mantenance more often. not to mention bugs and rodents like to find a warm place to hid with fee dinking water and a refrigerator provides that for them.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
