Question about 2wire 2700HG-B Router (2700HGB)
Can't get connected
Hi, I have just purchased a refurbished 2wire 2700HG-B modem/router from DigiDave on Ebay and although the wireless side is set up so that my laptop reports an excellent signal, I cannot access the web with the desktop even though it is connected via an ethernet cable. There was no software provided with the device and the user guide I got from the 2wire website does not help me to configure it. Can anyone help please. A software download would be of great assistance as the User Guide talks about installing software. I have had to connect my old modem, which is not wireless enable
Thanks in advance.
    Master:
    Sergeant:
  • 440 Answers
Try reset switch on back unplug it al then back in try again
Posted on Feb 04, 2008
I have purchased an AT&T 2wire 2701HG-B wireless DSL router to use in setting up a wireless network in my office. I have an external modem now that is part my AT&T internet service. Will the new...
The network appliance you're asking about is a modem with a wireless router built in. Basically, it's an all-in-one device. It will replace your already existing modem. It is a wise upgrade for any AT&T DSL connection.
Mar 12, 2011 | 2wire 2700HG-B Router (2700HGB)
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700hg-b modem/wireless router, my problem is i get lag while playing xbox 360 online, i get red bar to none , while my friend have all green bar,in the tv screen,also my laptop lose signal...
yeah a better modem would be the easiest thing to do because it's clear that the one you've got is either not transmtting properly or is just the unit you'vee got has a fault in it
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b wireless router
Hi, you will need a ethernet card in the pc to connect up a wireless router, most dont work with usb,
otherwise you would need a wireless adapter.
once you do get it connected, go into internet explorer and type in the ip adress for the router, will then come up with a menu for you to programme in your broadband details, once you get the router up and going, go into the PS3 settings, network settings, it will pick up the router all you need to do is enter the network key and its all go from there.,
ethernet card should cost you about £10 from any shop
Happy New Year
John
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
Slo connection to some sites
Log into the router's management console page at page at http://192.168.1.254/mdc
On the left side under "Advanced", click on "Configure Services"
Set the "Force Upstream MTU" value to 1396 then hit Submit. Reboot the modem/router.
Nov 28, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG - B
Log on to the routers interface and look for MTU size. Once you get there, reduce it to 1492. This will help.
- Ranjit
ranjit@supportminds.com
Nov 02, 2007 | 2wire 2700HG-B Router (2700HGB)
Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Sep 16, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
108 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
