SOURCE: dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
SOURCE: Format Error in Sony Cybershot
there is no tools feature on the sony...select the 1st button lower right...all touch screen features appear...select menu in lower
left...select setup...camera 1 will display...select down arrow
twice until you reach format, the select...that should reformat
the memory...
SOURCE: Cybershot camera not reading the memory stick
Have you tried reformatting your memory card itself?
SOURCE: Error E91:01 on DSC H7
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
SOURCE: sony cyber-shot dsc-w55 memory stick problem.
after connection with computer the camera do not show the auto run process
