Question about Gateway FPD2275W LCD Monitor
NEC LCD1912 LCD monitor, no power
I have an LCD1912 monitor, which just failed this weekend. It was not plugged into a surge protector, and power was briefly lost. When power came on, the monitor did not.
This unit is out of warranty. I know that NEC/Mitsubishi or a 3rd party depot can repair it, but I was wondering if anyone has successfully repaired this unit before. It is a couple components (possibly transistors) on the power supply side of the unit.
    Scholar:
  • 84 Answers
More than likely, the power surge burned one of the small resistors on the power supply or secondary side of power out put card. This is not a hard repair to diagnose or to make but you will not want a novice to do it as you can do more harm than good if you are not qualified with a soldering iron and multitester.
Better to take in for repairs, should not be that expensive from what you haev posted here to fix it.
Posted on Feb 05, 2008
I have a Princeton VL193 monitor and recently in will just power down. It just shuts off. If I unplug it from the surge protector and plug it into the wall outlet it comes right back up. When I plug it...
Monitor is erratic in operation - Power supply issue. Sooner or later the anomaly will become permanent and it will not power on. Just be ready for the eventuality.
Sep 14, 2017 | Princeton Digital VL193 19 in. Flat Panel...
I have a Dell LCD monitor (model number: E198FPf) that will not turn on. The power button is flashing and the monitor has a faint flicker with no discernable image. I removed it from the computer that it...
i believe you may have answered your own question here because what you are stating is a malfunctioned monitor if you plugged other monitors to the cpu and they worked and the monitor in question is not working maybe it was a storm surge and since it did not have a surge protector then maybe the monitor is shot and you may need to replace the monitor...
hope this helps
Feb 21, 2011 | Computers & Internet
Got a new surge protector/power strip. I
Hi
Please try the monitor without the surge protector to ensure there are no isues with the protector
If the monitor comes on you know its the protector, if it still fails then i recommned the following
1) ensure the fuse in the plug is ok and not blown
2) Change the 3 pin power socket for another one
If after this all fails then for some reason something has blown in your monitor and you will need to book it in for further inspection
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
Feb 12, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
How do you restart a nec lcd monitor, had power surge everything but monitor gets power?
The power surge probably blew the fuse inside the tv, first check the fuse inside the mains plug, if that is good then you will have to take the back cover off the tv, you are looking for the power board follow the mains cable into the tv and you will find it. Look for a fuse on the board, pop it out of the fuse holder, if you have or can get hold of a multimetre check the fuse for continuity if it hasnt you will have get hold off another fuse, you can normally get them from your local electrical repair shop, they dont cost much and the liklyhood is they will probably give you one free of charge.
Feb 04, 2010 | NEC MultiSync 1760NX 17" LCD Monitor
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
The power light is red and blinking rapidly, screen blank
is it plugged into wall or a surge? may make a difference. Some screens require certain amount of KV and some surge protectors have less KV than needed to run some things. good luck
Oct 01, 2009 | ViewSonic VX900 19" LCD Monitor
I have a sony wegs lcd tv with a seperate monitor and media centre. when I turn the media centre on the monitor lights up green on the stand by light and then afetr a couple of seconds the monitor switches...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
No power on NEC LCD1912 LCD monitor
NEC Repair Services of course, where he would order the replacement part; but given you can't use them without a Service Contract (four figures; yet useful for a repair shop with a corporate client with lots of NEC equipment) the diagnosis you got sounds reasonable. Find the NEC Authorized repair specialist in town with a bench fee you like, or go shopping!
I like the idea of reusing the old thing as much as anyone; if you can find the make and version of the working components, you're welcome to use them in native mode (no need for the control/interfaces chip; a PIC or other microcontroller can be substituted), make a projector, use the supply and other functions with their control lines 'tied low' with 200 ohm resistors, etc. I would be inclined to think that the video amps and detection circuits at the inputs failed (in hopes of saving the interior components,) and just replace those after I had some success driving the test points to force it into an ON state; but a positive ID of a bad chip is not going to put high hopes on that fix. A fixable unit would usually start to come on, then trip off when a failed functional section (or absence of video) was detected by a working control circuit.
Feb 22, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
152 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
