Question about Sony Handycam DCR-TRV350 Digital Camcorder
I have a Sony Handycam® DCR-TRV350 Digital-8 Digital Camcorder.
I can't figure out how to edit the tape from the camcorder. I tried to edit it through the pc, but I can't find the softward for it, so it wont work properly. please help me, thank you.
  • leelynn5 Aug 23, 2008
    I cannot down load from the camera to the pc because I,m running VISTA, it worked really well onthe XP I had but the software nor the drivers will work with VISTA, is there any hope or do I have to buy an old XP PC HELP IF THERE IS ANY
Eat
Posted on Sep 16, 2008
  • 3 Answers
Did the sony come with any editing software?
If not, then you will have to get some editing software for your computer. Then you hook the camera up to your computer and you can actually control the camera from the software. This will allow you to fast forward, rewind and digitize the video footage to your computer.
hope this helps
Posted on Feb 05, 2008
I have old tapes from an old camcorder Sanyo VM-D66P that I want to capture to my pc, how do I do this?
There are several ways of converting your tapes to a digital format.
1. By routing it through a DV camcorder with AV-input (these are increasingly rare though. (using firewire).
2. By using a device like this, which converts to DV. (also connects via firewire). http://www.dv247.com/invt/23453
3. By using a device which captures to MPEG2.
The cheapest way is option 3, but it requires a working camcorder. You should purchase a device similar to this: http://www.avforums.com/forums/attachments/camcorders-video-editing/85846d1216145397-camcorder-computer-easycap.jpg
If you don't have your camcorder anymore, or it isn't functioning, you should try to get a second-hand 8mm camcorder with firewire. This way you are able to directly convert your tapes to your pc.
If you can't find a firewire camcorder you could just settle with a good functioning 8mm camcorder but you will have to buy a capture device as mentioned above.
Jun 06, 2010 | Sanyo Video Cameras
Tape door wont close on my Sony CCD-TR416 camcorder
Try this for anyone having this issue:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Sep 22, 2009 | Sony Handycam CCD-TR416 Camcorder
Hd writer 2.5 editing issue
replace mt2s extension with other more accessible
Jun 08, 2009 | Panasonic HDC-SD5 Flash Media Camcorder
Sony camcorder copy tape to pc problem
Hi, You need to connect to PC using a 4 pin firewire cable. and then switch on the cam. Import the video using Windows Movie Maker.
Dec 27, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Importing camcorder videos from tape to pc
what cable are you using to connect your camcorder to the pc? and did you try to look at the manual for that situation. see also the settings from your camcorder before you connect it and look for the memory storage use or tape usage so that the appearance on the computer will be tape and not the memory card. can you pls give me some specific problems and details so that its not hard for us to solve your problem.
Needs
1.Cables like usb or firewire
2. installer cd camed from your camcorder
3. uploading software such as ulead movie director or movie maker, Windows moviemaker, Nero movie maker etc.. or whatever software you have.
4. Edit and save
the following steps are needed to transfer your videos to your computer.
tell me what you have.
CHARCOIS
Oct 17, 2008 | Canon MV650i Mini DV Digital Camcorder
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sony Handycam DCR-TRV350 Digital Camcorder Logo
85 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
