Question about Lexmark Optra E312L Laser Printer
Paper feed The printer makes a groaning noise as the paper begins to feed and then stops with the paper halfway behind the ink cartridge and all lights blinking.
  • lhfineman Feb 05, 2008
    There is a wide rubber band at the center of the axle, and it does seem to be the source of the sound, but I don't seeanny other place that it should be.
  • T1mb0 Apr 07, 2008
    I had a similar problem with the groaning and then the paper stopped. The diagnostic error confirmed it was a laser scan head error and I traced the groan to the laser scan head unit. Initially I was thinking "oh no. this is going to be expensive". I worked out it started groaning when the little motor that spins the hexagonal mirror had some issues. I took it apart, cleaned out the crud, gave it a very light grease with some centrifuge grease (I work in a scientific lab). I assembled it and this is the bit that was critical. I noticed the mirror had a dot of glue on the top surface towards the edge. This is clearly to balance it make like you would a car wheel with brand new car tires. I match up the glue mark to a pen mark on the heavy part of the mirror unit. I was able to rotate this bit around relative to the mirror. I assembled it and tested it. It worked wothout groaning and I managed to get pages printed. I now have to fix all the paper feed problems.
  • 3 Answers
My e312l has the usual paper feed problems (no feed and multifeed). I bought it like this for $20 off Craigslist because it came with a brand new 6000 page toner and I figured it was a bargain if I could fix it. I downloaded the service manual to identify the parts involved. And post on the internet have really helped out. I've cleaned all the paper feed/seperator pads and rollers but this was only a short term solution. It worked OK for about 2 days. I did noticed that the pick roller assembly (part# 12G1933) tire is suppose to look like a "D" but was worn asymmetrically at the point where it first makes contact with the paper. I disassembled the printer to get to the pick roller assembly and took the tire off and flipped it end-over so the less worn point of the D was now in contact with the paper. This totally worked although at some stage I'll have to find a new tire. Where can you just buy a new tire for like $2 instead of the whole assembly for $30+?
Now I only have the multifeed problems to solve. Hopefully a new seperator assembly pad (part# 12G0064) and a new pick roller assembly pad (part# 12G0062) will sort it out and bring it back to like new. I'll add more posts when the new parts arrive.
T1mB0
Posted on Apr 07, 2008
  • T1mb0 Apr 08, 2008
    To solve the multifeed problems I replaced the following. the separator assembly pad (part# 12G0064), pick roller assembly pad (part# 12G0062) and the friction pads. Using the web I spent a few hours and I shopped around and got the cheapest parts all from the same place to save on shipping. It was a pain to strip the printer apart yet again. When I pulled the old bits out I realized how warn they all were and clearly they needed replacing. I reassembled the printer and my paper feed problems are considerably better. It still loaded 2 sheets of paper when the guides were not tight enough. I'll keep the guides tight and maybe use some thicker and smoother paper. I don't think I can do any more to make this printer better. I threw in a 32Mb stick of cheap memory too. I now have a fully functioning printer!
    T1mb0
  • 417 Answers
Hi seems to me that the paper feed separation pad is not in the correct place check and clean this should help if not get back to me.
Thanks J
Posted on Feb 05, 2008
Paper feed problem
The clicking noise is an indication that something's not right in the printer. But try taking out the cartridges from the printer. Then, close the cover. Remove all sheets of paper. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Wait at least 10-15 seconds before plugging it back in. Once printer's ready, reload the cartridges. Load some paper and try to print again. If this doesn't help and you're still getting that continuous clicking noise, it's a hardware issue. If that's the case, I strongly suggest you contact Lexmark Technical Support for further assistance. I hope I can assist you more on this.
May 28, 2010 | Lexmark X83 All-In-One InkJet Printer
My printer thinks it is out of paper when it
please try to set it to manual feed
with manual paper feed it wont search for a paper and wont give an error
Thanx and i hope this helps
PLease rate this solution
Jul 16, 2009 | Epson Stylus Color 777i InkJet Printer
My roller dont take in the paper
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
Printing stops halfway
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | Lexmark All-in-One Printer with PictBridge
Dont know how to remove the ink cartridges from Canon iP4600
managed to get the ink cartridges out and put them back in again.It was vert tricky to get them out.They have to be pushed out from the top of each cartridge first. I got a work colleague to do it for me and he agreed it was very awkward to do compared to other printers.
Jan 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Printer jam
open top cover of your printer and put a couple of drops of 3 in 1 oil on the carrige bar ( THE BIG SILVER BAR THE INK CARTRIDGES RIDE ON)
THEN CLEAN ALL THE RUBBER FEED ROLLERS WITH A MICROFIBER TOWEL MOISTENED WITH ISOPROPANOL ALCOHOL THEN TRY THE PRINTER AGAIN
Jan 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Optra E312L Laser Printer Logo
555 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
