Question about Panasonic DP-C264 Copier
Mail merge tri fold printing
Konica minolta c550 will trifold all sheets sent to it together. we do a mail merge and instead of the sheets being folded separately, it will clump them together. can't fold more than 10 sheets at a time and will not fold them at all if you send more than 10 sheets to the printer. we do 100 - 200 mail merge letters at a time and need this feature to do the job most efficently. got any suggestions?
We fought this same issue.
This should solve your problem.
In the print dialog button, select pages 1-x rather than ALL, or edit the registry to define a batch size of one instead of 10. This solution should be valid for all copiers with collate, staple, or fold finishing capabilities. See instructions here:
http://support.microsoft.com/kb/891904/en-us
Posted on Sep 21, 2008
  • Panasonic Expert
  • 1,326 Answers
Whats the weight of the paper? Try a lighter weight paper. Also, did it do it when you first got it? If No, it is called a limitation, it can't be done. If it did have your service tech come out and clean or replace the feed rollers or clutchs.
Posted on Feb 07, 2008
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
THe printer will not fold the merged leters
There is no Tri fold feature on this model!!
you can only do half fold in booklet mode if you have Sadlestich Finisher installed. Panasonic color models did not come with trifold feature.
I am a trained professional on Panasonic color copier
I can provide any help you need with this model
Apr 10, 2010 | Panasonic DP-C264 Copier
Konica Monolta c550. ignores trifold
the fold function is only available when the option finisher fs-608 is installed . here is the steps to make a trifold on a fs-608.
1 open a one page document it can only be 8.5x11 in size.
2 click file then print and pick the konica c550 in the printer name box. click properties.
3 in the output method select print leave the paper tray on auto leave the paper size on same as original click original size to indicate 8.5x11click on the radio dial to indicate portrait under original orientation.
4under the layout tab leave the following fields blank-combination,rotate 180,skip blank pages,binding margin and image shifton the right side of the layout screen leave print type as one sided and binding direction on auto.
5 under the finish tab leave paper arrangement at its default= prioritize arranging papers.make sure there is a check mark in the fold box and select trifold in the drop down menu.
6 click ok and go to the c550 to retrieve the document
Nov 05, 2009 | Panasonic DP-C264 Copier
I am trying to print a booklet with eight pages front and back from publisher 2007 on a Konica Minolta Bizhub C550 and when I print one copy it folds and staples fine. When I print two or more copies the...
first change driver, second print to hdd in printer, and then call this job from hdd and change copy amount. if this is not helping, then maybe the firmware is faulty, fw update is good idea
Oct 15, 2009 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica minolta 600 has problem printing duplex mailmerge and tir
CAUSE: The tri-fold printed on side is set incorrectly on the machine.
SOLUTION: To change the tri-fold from printing inside fold to printing outside fold, perform the following:
1. Press the Utility key.
2. Select Admin mode and enter the password.
3. Press Copier Setting.
4. Press the down arrow.
5. Press Tri-Fold Printed on Side Selection.
6. Press either INSIDE or OUTSIDE.
good lock
Feb 28, 2009 | Panasonic DP-C264 Copier
Panasonic DP-C264 Copier Logo
756 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
