Question about Hoover V1 SteamVac SpinScrub Vacuum
Loud Grinding Noise
Bought a steam vac from a garage sale. I'm a first time user, and it worked great, but ehn all of a sudden it started making a grinding noise, so I turned it off, and it will not power back on. My husband checked for something possibly stuck in it, or a busted belt, but can't seem to find the problem. He also noticed that the fuse did not burn out. Is there something in it that can be replaced or is the motor burned out?
  • colleenk77 Mar 07, 2008
    hello! i have had my hoover steam vac for a few years and worked great until today when it also makes griding like noise and it kinda smelled like a belt but the manual does not say anything about a belt for this unit. It still turns on but smells like a burned belt or is it motor? help!!! I am have done with my carpet and need to know so in case i have to replace the unit all together!!!
Jhu
Posted on Nov 09, 2008
    President:
  • 1,673 Answers
Take out the brush block and see if it will power on, if not then probably your motor has gone bad.
Posted on Feb 05, 2008
I have a model f7411900 steam vac from Hoover and it started making a loud noise like a broken belt does in a vacuum. Does this have a replacement bely
Open the product, make sure first that it is not something stuck inside. If it is a belt, check with amazon. Just make sure that you have the correct model.
Aug 24, 2016 | Hoover F7411900 Maxextract Dual V Carpet...
Hoover steam vac spin vac making loud noise sparks flying
The only source for electrical sparks is the motor so it must be checked. Bad motor brushes or a broken wire are possible causes. Do not use in this condition.
Aug 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
My hoover Model F5858-920 bushes stop turning how can i fix it?
1. Check to be sure recovery tank is on right. This is the problem 99% of the time the brushes use a turbine powered by the suction.
2. Check to be sure the brushes are set to "on" if it has that option. And that the screen filter on the front of the machine is clear.
3. Check the brush block by pressing the 4 tabs holding it in place under the machine. It will slide out. It should turn easily. If the tab to turn them is broken they will not work either. This is what they should look like:
http://www.vacuummedic.com/product.php?id=206
4. Place a screwdriver in the socket that turns the brushes, it should turn slowly but fairly smooth. It should not make any grinding or foul noises while turning or if it is frozen solid it is bad. This is the replacement part for that:
http://www.vacuummedic.com/product.php?id=229
The Vac Dr.
Sep 09, 2012 | Hoover Steam Vac Carpet Cleaner Spinscrub...
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Water is leaking from bottom of cleaner
you may just have a split pipe from the water tank and thats why its leaking water out
Jun 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Shark steam blaster jr. makes steam but has no pressure
yes no vinegar please. Try a product called scale clean or tablets for de-scaling coffee machines. Available from coffee machine retailers
Sep 19, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Hoover V1 SteamVac SpinScrub Vacuum Logo
228 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
