Problem with sending faxes
When I send a fax, I put the paper in the doc feeder, type the phone #, press start, and then the feeder takes the paper half way, stops, then starts to dial, then stops and then prints out a transmission error. I don't think anything is sticking in the doc feeder because I can make a copy just fine.
  • Carrollson Feb 07, 2008
    I pushed the direct tx button by mistake.
  • 106 Answers
Change a paper size in the fax setup
Posted on Feb 05, 2008
I am trying to send a fax on my parents fax machine but do not know which way to insert the paper. It is a brother MFC-7860DW
  • if you are going to fax from the glass or scanner bed you should put your document face down on the glass
  • if you are going to fax from the feeder (on the top of the machine) then you should load your document face up in the feeder
How to send a fax?
  • when you want to send a fax ,press the FAX key to illuminate it in blue
  • put the document either in the feeder or on the glass
  • enter the fax number using the dial pad
  • press START
Jul 29, 2011 | Brother Office Equipment & Supplies
Won't transmit
open the doc feeder
turn machine off
hold down the pointy black switch actuator while turning the machine back on, hold until machine beeps, close doc feeder
scroll down to SHIPMENT SET
press SET
press 2
wait for reboot
to set time:
key in the date and military time
Feb 03, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Dec 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Instructions on how to send and receive a fax.
For most fax machines:
1. Choose the "Fax" option
2. Place paper in feeder tray
3. Dial phone number
4. Press the start/go button, usually green
Hope that helps
Apr 30, 2009 | Office Equipment & Supplies
Help when i try to fax using my brothers 560, the number dials, the machine sounds like it's faxing, but the disply says telphone. how can i correctthis
Do you pick up the hand set when you are dialing, If you do the display will read telephone. When you want to send a fax put the paper in the document feeder. Dial the # press the start key or put the documents in the document feeder press the hook button to here the dial tone, dial the number what for the tones pres the start key. hope this helps
Jan 29, 2009 | Brother IntelliFAX 560 Plain Paper Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Brother 575 fax
The papers you are sending go into the front feeder with the copy facing the back. Then just punch in the fax # and press start.
Jul 16, 2008 | Brother FAX-575 Plain Paper Thermal
Problems sending faxes with B820
make sure it says doc ready before pressing start!
Feb 28, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Can't send any faxes
Hello,Mafriend,It sounds like you might have recieved a Fax machine that Recieved a surge,To verify this Ck the Jack where the Phone line goes in to see if you have any type of discoloration there,also see if it locks up your phone line from making calls or recieving Them ttech
Jul 20, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
163 people viewed this question
