Question about Rival CF153-WM Deep Fryer
Cleaning How do you remove the oil reservoir for cleaning. Thank You Gerri
  • skw42 Feb 24, 2008
    I am unable to remove oil reservoir, aluminum cooking pot.
    I tried pulling up. Manual shows it out of housing.
    Thanks,
    SKW
  • 77 Answers
Is there a small button or something on it somwhere
Posted on Feb 26, 2008
WHAT CAN I DO WHEN OIL MISSED WITH WATER IN MY AUDI Q7 2008
Sounds like you have either a leaking intake manifold gasket or a leaking head gasket... either way.. its time for a Qualified Professional...
Jul 26, 2017 | Audi Cars & Trucks
The oil has stopped oiling the chain on my mountfield chainsaw
if your reservoir is full of oil then remove bar and clean oil hole. they do get plugged sometimes
Sep 16, 2014 | Garden
Wrong power steering Fluid
open the oil return to the reservoir and drain out the wrong oil. refit the hose and refill with the right oil . run and turn the wheel from lock to lock to remove air and old oil. remove the hose again and repeat the process several times until clean oil comes out the return line . Refit the hose and fill with the correct oil.
Jan 01, 2014 | 2004 Hyundai Elantra
Wiper reservoir filled with oil instead of windshield fluid
Sometimes they have those reservoirs recessed so far under stuff it is difficult to get to. Don't give up, though. There is always a way, and they are removable. Some are pulled off from the bottom. Some are placed behind a shield in the front wheel well. Usually only a couple of screws retain it. Pull the hose off, the motor connector, unfasten the screws and it should be free to come out.
Jul 17, 2012 | 2003 Mercury Grand Marquis
Where is the transmission oil serviced
Run the Low Rider's motor for a few minutes to warm the oil up. Shut off the bike.
  • 2 Find your Low Rider's drain plug (on the oil pan). Using the screwdriver, loosen then remove the drain plug, and drain the oil into the drain pan.
  • 3 Remove the Low Rider's dipstick.
  • 4 Let the oil drain completely.
  • 5 Clean the drain plug threads with a clean cloth or paper towel, apply sealant, and replace the oil plug and dipstick.
  • 6 Move the drain pan to beneath the oil filter. Using the oil filter wrench, remove the oil filter.
  • 7 Discard the filter in the pan with the old oil. It is full of oil.
  • 8 With a clean rag or paper towel, clean the area where the gasket meets the motor.
  • 9 With a clean finger, rub a bit of new oil on the gasket of the new oil filter before installing it.
  • 10 Install the new filter, turning until snug, then turn it by hand another 1/2 turn. Take care to not over-tighten, as this will damage the filter gasket or the filter, possibly causing the Low Rider to fail.
  • 11 Open the oil reservoir, using the funnel; fill the tank with the fresh oil and close the reservoir.
  • 12 Run the motor for a few moments to coat the engine with the new oil. Check for leaks. (If you find any, check the filter and drain plug for a tight fit.)
  • 13 If there are no leaks, after the motor has run for a few minutes, turn off the motor and check the oil level. Top it off if necessary.
  • hope this helps
    John
    Jan 10, 2011 | 2003 Harley Davidson FXDL Dyna Low Rider
    How do I remove the oil reservoir to clean it?
    hello,
    We had same issue. My husband just unscrewed and removed the metal plate from the bottom of the unit looking for a solution.
    The reservoir cannot be removed. The heating coil is permanently attached (welded?) to the bottom of the reservoir.
    It is obvious, now, that the reservoir is not intended to be removed.
    Ignore the statements in manual that say the oil reservoir is oven safe and not to remove it until it's cool. They do not apply to this model
    thanks.
    Oct 03, 2010 | Oster Microwave Ovens
    Can't remove the oil reservoir to clean it.
    We had same issue. My husband just unscrewed and removed the metal plate from the bottom of the unit looking for a solution. The reservoir cannot be removed. The heating coil is permanently attached (welded?) to the bottom of the reservoir. It is obvious, now, that the reservoir is not intended to be removed.
    Ignore the statements in manual that say the oil reservoir is dishwasher safe and not to remove it until it's cool. They do not apply to this model.
    Dec 28, 2009 | Oster Kitchen Appliances - Others
    I had to rev it to start and it would often die at intersections
    There should be a pressure switch for the power steering that regulates rpm' to the computer.
    It should have an electrical connector on it and located on the rack and pinion assembley.
    Jun 18, 2009 | 1997 Dodge Neon
    What kind of oil do I use in the oil reservoir of my chain saw?
    I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
    Apr 26, 2009 | Remington 16" Electric Chain Saw
    Leakage
    The fix is to unscrew the drain plug from the oil reservoir. As the oil drains into it, the air inside is displaced and needs to go somewhere. The left over oil from previous drainings has caused the reservoir to become an airtight seal making the oil compete for the trapped air for the space resulting in the much of the oil giving up and draining over the top instead of pushing the air out. Removing the plug allows the air to escape as the oil rushes in. Only problem with this solution...I've now lost my drain plug because I took it out to drain and misplaced it. T-Fal doesn't sell replacement parts and instead I would have to shell out $15 plus shipping for a new reservoir from a 3rd party repair center. For now a paper towel stuck in place of the plug is getting me buy.
    May 15, 2008 | Tefal Ultimate EZ Clean Pro Deep Fryer
    Rival CF153-WM Deep Fryer Logo
    126 people viewed this question
    Top Rival Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Ric Shull
    Ric Shull
    Level 1 Expert
    Craig Butler
    Craig Butler
    Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
