Question about Dishwashers
GE Max dishwasher no lights on panel
GE Max dishwasher. Lights on panel were confused. Reset the breaker for the dishwasher. Worked fine. Next load I closed the door and no lights on panel. Tried resetting breaker no success. Dishwasher is receiving current but the controls show no lights. Dishwasher inoperative.
I have left a message for a repair service to call.
  • dgoos Jun 23, 2008
    Repair man found a wiring problem and did a repair.
    I would never have found it.
  • whahappened Aug 03, 2008
    control panel not working after lightening flickered lights although the washer was not running since then cant reset the panel to anythingg but 100 min. and a green light.
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Posted on Mar 22, 2008
Installed a new control board in GE dishwasher: GLD6860NSS. Still having problems!
check the board for a dry joint where wires are soldered to it. I researched this problem before. It was where one board was wired to another. Bad joint was not supplying enough power.
Mar 23, 2017 | GE GLD6860NSS Stainless Steel Dishwasher
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
START/RESET LIGHT STAYS CONTINUOUSLY ON
you do not mention the make or model nor do you mention if this was the case since purchasing dishwasher. But before you repost, turn off your breaker to the dishwasher for at least a minute to reset the dishwasher. Hopefully this works. The other options get far more involved and some of them are not for most DIY.
Sep 19, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
The panel on my ge profile ss dishwasher is not working...
At first thought, it sounds like the control board has gone bad. Make certain it is properly plugged in. If no luck there, call the repairman.
Feb 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
784 people viewed this question
Top Dishwashers Experts
