Question about Maytag MGR5751AD Gas Kitchen Range
May tag gas range 30 inch
I have recently installed a new oven igniter which i assumed was the problem however it was not ,when the oven is on and cuts out at the required temperature and then cuts back in it makes a gurgling noise and i have to shut it back off.
  • John Prior
    John Prior Mar 21, 2008
    I had assumed my igniter was bad but it's still not working. I don't have a meter but I bet it not getting voltage. Is there a fuse in line?
    Novelist:
  • 166 Answers
Peace,
ngafm here at your service,
i think that gurgling noise is the gas trying to get out and is neing blocked by a over boil or food spill on the sealed burner with the holes clogged!
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that one burner.
Or you just have a bead igniter.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Posted on Sep 05, 2008
6ya staff
SOURCE:
Brown gas range auto ignition not working
If the problem is with all the burners then the igniter module may be defective. If this is happening only with some burners then the cable to the ignition point has become loose or is shorting with the body.
I am assuming the model number is correct but I am not finding any details for this 24 inch freestanding gas range. If the oven is electric and if it is running that means at least the electric power is reaching the unit.
Brown Stove Works INC
The oven parts are available here
Brown Range Stove Oven Parts
Sep 03, 2014 | Brown Stove Works TM110-3 Gas Kitchen...
Circuit breaker 30 or 40 amp
Electric range normally takes 50 amp breaker. Are you installing new line for this range? Normal practice is seu aluminum cable #6/ 3 conductor
Apr 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont heat
This may be a control panel issue. i would also check the glow ignition as well , assuming it is a gas range.
Feb 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven will not ignite
I would be suspect of the temperature control valve based on your previous experience. I am assuming the safety valve you are speaking of was really a regulator.
Jan 28, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven takes longer than expected to light
You probably have a bad gas valve, part # WB21T10014, unless the new igniter is defective. If your broil works, you can prove this by temporarily hooking the broil igniter in the bake spot. Hope this helps!
Jan 01, 2009 | GE Profile JGSP48 Gas Kitchen Range
Oven takes way too long to heat
This advice is for GAS ovens with glow bar type igniters. This is how to determine if the igniter is bad. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance.
An igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad. An igniter should only take 30-90 seconds to ignite.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
Mar 24, 2008 | Whirlpool SF315 Dual Fuel (Electric and...
Oven does not ignite
that red tag is a shut off valve for the regulator. what you need to do is to try to get the red tag back on if it is not broke, look at the red tag because it snaps back on the regulator which has a hook for the red tag to fit in once it is in the red tag flips up in the on position and that opens the regulator  to release the gas if it is in the down position once you have it one it will shut the gas flow off so make sure it is in the up position. If it is broke you have to replace the regulator.
Oct 02, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE Profile Spectra JGBP85WEB5WW
im assuming you dont have to light the pilot.if thats the case and you replaced the ignitor assembly it could possibly be the ignition module/board.
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR5751AD Gas Kitchen Range Logo
162 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Marvin
Marvin
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
