RCMP Frequencies I have been listening to the RCMP for 40 yrs -- now they have changed there frequencies over to trunk tracking,now I can't find them in Saskatchewan? Can you help. Thanks, Jrbuck;
  • okleo May 26, 2009
    nipawin RCMP freq codes changed , can any one HELP
Check the RadioReference website. in the moose jaw area they are in the 138 and 139 MHz range. However, the new system frequencies are useless to you unless you are using a APCO25 compatible radio (Digital scanner).
Wil
Posted on Apr 12, 2008
  • ve5wil Oct 31, 2013
    Further to last post RCMP in Saskatchewan are not fully encrypted. Can not hear them at all now no matter the scanner
    Pops in Saskatchewan are NOW fully encrypted... Dang autocorrect
My squelch button stopped working on the BC898T Base Scanner
Trunking is designed this way. You wouldn't want to listen to the control channel data, or you would never hear any of the actual radio calls. It sounds like it is working as it should.
Oct 05, 2012 | Uniden BC898T Base Scanner
My scanner no longer scans the local police and sheriff frequencies. It will only scan the next county sheriff frequencies. It was originally programmed to scan Omaha police and Douglas Co. sheriff.
It's possible that your county services have switched to a trunking system, leaving you with nothing but "dead" frequencies. To check the frequencies and systems that are currently in use in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
May 29, 2011 | Radio Shack Pro-97 Handheld Scanner
Hi - I don't know any frequencies to enter on my PRO-94. Is there a way that I can just scan all local channels?
You can run service searches as described in your manual to locate active frequencies, but those won't help with trunked systems. You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, by visiting:
Bill B.
Mar 06, 2011 | Radio Shack Pro-94 Scanner
Cannot recieve new Motorla trunking Feq after system upgrade on my Pro 95 scanner. What can I do?? Thanks, Ron
Hi.
They probably went into a digital trunking system. Your Pro-95 will only handle Edacs, Type I and II standard trunking.
Or they changed the trunking voice frequencies and the data (control channel) frequency.
Which system are you trying to listen to? Which city area ??
Feb 09, 2011 | Radio Shack Pro-95 Handheld Scanner
What are trunked freqencies
A trunked radio system is one where users share a number of frequencies that are rotated by a computer, and while your scanner may be able to tune in to specific frequencies within the system, it is not capable of following a user when the frequencies are changed. In other words, you may pick up a lot of activity on a frequency in the system, but you'll have a bunch of partial, cut-off conversations involving different users. For more information/discussion of trunked systems, I suggest that you visit www.RadioReference.com
Bill B.
Jan 22, 2011 | Uniden BC60XLT-1 Handheld Scanner
I NEED TO KNOW HOW TO ENTER CODES INTO THE SCANNER
hi what do you mean by codes ,or do you mean frequencies ,to enter frequencies press the program key enter the frequency you want to listen too and press enter you can select different banks for different communications ,such as emergency,air traffic,marine,rescue,etc hope this helps
Jan 08, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I cant listen to the police
First, make sure that you have the correct frequency for your local police. You can find a comprehensive database of active frequencies in your area by visiting:
www.Reference.com
Program the frequency or frequencies using the instructions in the scanner's operating manual. and you should be all set. If you need the manual, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
NOTE: If the frequency database shows that your local police are using a trunked system, you will not be able to monitor them using the BC60XLT-1. Trunked systems require a trunking scanner. Many law enforcement agencies are also using digital systems for their communications. If that's the case in your area you'll need a scanner capable of monitoring APCO-25 digital transmissions.
Bill B.
Nov 13, 2010 | Uniden BC60XLT-1 Handheld Scanner
Can you listen to a police frequency if it's trunked with this scanner? Uniden BC72xlt
You can listen to trunked police bands UNLESS: 1 they went Digital and your scanner is Analog. 2. They use an encrypted control frequency. 3. It is not against the law in your area. 4. you have a Trunked scanner. Following trunked frequencies requires a trunked scanner which is very different from regular everyday scanners. If the photo of your scanner is accurate then it appears you have Digital capability so that won't be a problem. You can go to Radio shack and purchase a book on Public Safety frequencies and Control Frequencies which will give you the proper frequency range but they will tell you nothing about Encryption on any Frequency. If you can not find a Control Frequency then you will not be able to track the hoping that is used in a trunked system. By the way, a Regular scanner runs about $50 where as a Trunked Scanner runs $150 to $200.
Oct 16, 2010 | Uniden BC72XLT Handheld Scanner
Codes to reprogram
Do you mean the frequencies to listen to, or how to program it. Radio Shack has the programming directions, but the frequencies are local to you. This is not a digital scanner nor a trunked scanner, in which case, if your local PD/FD switched to a trunked system or digital trunked system you will need a new scanner. You should be able to program in your local weather radio channel, like 162.550 to test the unit though.
Dec 29, 2009 | Radio Shack Pro-2018 Scanner
1,326 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
