Question about ViewSonic VA721 17" LCD Monitor
The Right Half of My Screen Is Grayed Out
The right half of my monitor is gray. It is not my video card. The right side suddenly went grey. I have had this happen to me before. I did nothing and it worked again. Also, it looks like two pins are missing on the connector. Thank you.
  • bhcra Apr 09, 2008
    When I boot up the left side on my screen is dark. It slowly brightens after a few minutes. Is this a sign of the monitor going bad.
    Problem Solver:
  • 17 Answers
It seems unlikely that two pins would be missing. They would more likely be bent down. If there's no bent pins, it looks like it could be a faulty monitor. Certainly, when TFT displays go, they tend to manifest the fault in a colourless or multicoloured bar consistently across a portion of the screen.
Posted on Feb 04, 2008
Half of the monitor screen went dim
Faulty screen? Try an external monitor to prove it.
Apr 08, 2015 | HP ProBook 6440b Notebook
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
My Acer Aspire One has half a good screen and half a black screen. Everything seems to be working as long as you only use the left half of the screen.
Power it up with an external monitor connected. If you get a full display on the external monitor, this confirms you have a problem with the built-in screen or the built-in lead connecting it to the motherboard, and not an item like the motherboard or built-in graphics chip (which are used regardless, whether image is sent to the internal screen or external monitor). The internal screen can be replaced, but before doing that, I'd suggest checking that the internal lead from the motherboard to the screen is intact and secure. Unfortunately, this entails some disassembly, which most home users would not be comfortable with.
Nov 12, 2017 | Acer Aspire One 521 532H 533 D260 NAV50...
Monitor looks like right half blue shade
Either your monitor or the video card inside the computer is going bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok that means your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same blue shade then your video card inside the computer is bad.
Jun 05, 2012 | Lenovo Computers & Internet
Right half of screen out
This is a problem in the processing of the video signal, cheaper to replace the DVD player.
Mar 06, 2012 | Televison & Video
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
Philips SAA 7130 Not Picking Up All Cable Channels
USUALLY WHEN AN OPTION IS GRAYED OUT IT MEANS YOU HAVE TO BUY A PREMIUM VERSION OF THE SOFTWARE TO " UNLOCK " THE GRAYED OUT AREAS. CHECK WITH YOUR TV TUNER CARD FOR UPDATED SOFTWARE OR ASK THERE TECH SUPPORT IF THIS IS THE CASE. IF YOU NEED MORE HELP, REPLY TO : ARCLIGHT1217
Nov 16, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
ViewSonic VA721 17" LCD Monitor Logo
366 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
