Question about Gateway FPD2275W LCD Monitor
Envision model H190L ser#91077CA000122 cannot change resolution
Monitor used with G-5 Mac..cannot change resolution from 800x600 in the mac's system preferences display window... when 2 monitors connected, then I can change the resolution on both the H190L and the other monitor. please help.
  • Anonymous Mar 22, 2014
    Verified power to unit. No power light. Will bad capacitors in the power supply cause the power light to not light?
  • 2,351 Answers
Mac's a bit differant than windows. To change your screen resolution first change the monitors refresh rate to something like 75 hertz. Than you can change the Screen resolution. Thats how it is done on a windows machine. Than again your Mac might need a video card software update.
Posted on Feb 05, 2008
  • Mike Peluso
    Mike Peluso Feb 07, 2008
    Look at pg. 7 in your manual for the H190L. This monitor only supports what is listed. And looking at your H190L I see only 1 VGA output. So If you connected two monitors than the Mac has dual VGA outputs. Is this correct? How about plugging the the H190L into the other VGA connector on the Mac with out the other monitor & see if you can change the screen resolution? I'm not a fan of Mac's I admitt that. Though in many respects windows & Mac's are similar. Your video software must have software installed in order to support two monitors. That is were you need to go & setup 1 connector's output. Than you should be able to correct the display's resolution to your preferance.
Power problem
Probably the power supply is failing.
Sep 02, 2012 | Envision H190L Monitor
I cannot install adobe pagemaker 7.0
Did you see the system requirements? Here's it - try to see if its fit to your system For
  • Intel® Pentium® processor
  • Microsoft® Windows NT® 4.0 with Service Pack 6, Windows® 2000 Professional with Service Pack 2, Windows XP Professional or Home Edition
  • 32MB of available RAM (48MB or more recommended)
  • 175MB of available hard-disk space for installation (200MB or more recommended)
  • Video card with 800x600 resolution and 8-bit/256 colors (24-bit, high-resolution display recommended)
  • CD-ROM drive
  • For Adobe® PostScript® printers: Adobe PostScript Level 2 or later
for Macintosh
  • PowerPC® processor
  • Mac OS 9.1 or Mac OS X (Classic mode only)
  • 30MB of available RAM (45MB recommended)
  • 150MB of available hard-disk space for installation (200MB recommended)
  • 800x600 monitor resolution with 8-bit/256 colors (24-bit, high-resolution screen display recommended)
  • CD-ROM drive
  • For Adobe PostScript printers: Adobe PostScript Level 2 or later
If you think your computer system got all of the above requirements, Perhaps there's a problem of your computer Operating System. Try reformatting it.
May 18, 2011 | Adobe PageMaker 7.0 for PC
Power button locked, to unlock...
You may wish to try this (my model AOC g2016wa2)
1. push MENU button
2. scroll to Advanced
3. push MENU button
4. scroll to Factory recall
5. push MENU button
It resets the power button locked setting but you lose all other settings.
Feb 24, 2010 | Envision H190L Monitor
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Resolution to big
Check your grahics card to make sure it supports higher resolutions. It may be that you have it already set to highest supported by your video card. Hope this helps.
Dec 27, 2008 | Envision H190L Monitor
EMac screen resolution size is only one choice 800x600
1st start it in safe mode.install video driver from motherboard support cd.then start it in normal mode.then you may change your monitor resolution.
Feb 08, 2008 | Apple eMac G4 M9425LL/A Desktop
Without knowing any more about your system I can only give you a couple of general ideas.
First try updating to the newest video card drivers possible.
You can try going to the drivers tab in display adapters in device manager and click update drivers.
Failing this, if your system is more than a few years old you will probably have to update to a more current video card to get the resolution that you need.
The native resolution for your screen is 1280x1024.
Jan 03, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
244 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
