Question about Toshiba Satellite P105-S6024 Notebook
Battery problem my battery will not charge and the light flashes orange. I have a brand new battery and cable, but it still will not work. Any help?????
  • 2 more comments
  • uttermission Feb 04, 2008
    I have a brand new power unit and battery. Battery does not show charge at all, the light just flashes orange
    I have a new charger, it still does not work. That is my problem. I replaced the charger and the battery and it is still not working
  • zoemonte Mar 15, 2008
    Battery will not charge. Cannot turn computer on w/ battery or adapter plugged in. Green battery light flickers weakly but computer won't turn on. Replaced battery but same thing happening.
  • flyingfull Dec 26, 2008
    I have the same. Replaced the battery, now orange light flashes, but doen't charge battery. As soon as I unplug it powers off. What is the fix?
    Toshiba A85-S1072
    Master:
    Sergeant:
  • 440 Answers
U try new power plug unit supply next i would try that or does battery show full charged but wont start then mobo has bad power chips on it they can redo them or u can buy new mobo to install in also cheak screen cond cables ect
Posted on Feb 04, 2008
  • nick helpap
    nick helpap Feb 04, 2008
    Ok well u want new charger then ok aint getting no power rate this as fix ya so it will help others thx agian for using fix ya nick
  • nick helpap
    ok next step is cheak mobo power chips if u dont know how u can buy whole new mobo and replce it off ebay or sell yours on ebay for parts mobo not sending power to the battery bad chips cused from over heating do uuse it on a bed alot air sucks from bottem up out back ok always hard top areas
3 Suggested Answers
  • 21 Answers
SOURCE: The power light blinks orange
Sounds like you have a bad charger.
Posted on Jan 07, 2011
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
Inspiron 6000 flashing orange light for three batteries. I took apart two, made one using three groups of three cells that were fully charged and rebuilt another with brand new cells, and both get the...
The flashing orange LED is a Battery Critically Low indication.
If the Windows Battery Meter and the BIOS do not show the batteries charging then there may circuit problem in your battery.
If you can, try battery in another system, if you can't, I'd try a new battery before doing any hardware changes to the system
Dec 24, 2009 | Dell Inspiron 6000 Notebook
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
After doing a hard reset on my HTC TyTN 11 it just hangs at a message that say "The device is clearing the storage..please wait" .I have switch it on and of nothing changes..same message appear after...
Hi you seem to either corrupted the storage card of the flash memory. In either case you have to remove the battery physically for 1 minute and try again.
Jul 24, 2009 | HTC TyTN II Smartphone
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Dec 29, 2008 | Acer Aspire One AOA110-1626 Notebook
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
When I try to charge the battery the light just flashes and the charger does not work.
Hi, I had the same problem!
Had not used my camera for a while so I decided to but my battery on charge, once in the charger the orange light just kept flashing so I left this in "flashing" for a good hour or so.
I removed it and then replaced it, and it was still flashing so I decided to get a new battery (£40!).
I put the new battery on charge over night and it charged great, so I thought I would re-try charging my old one before I sent it away for recycle, and guess what the orange light stopped ON and it was charging!
Not sure what happened here, it was either charge the old for an hour with light flashing and then remove and leave over night and re-try OR insert a good battery to re-set the charger?
But I now have 2 good batteries.
Hope this helps :)
Apr 23, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Brand new psp battery will not charge
Did you charge it first? You need a good initial charge. Depending on the charger, it could be about 6 hours.
Also, remove the battery and check the metal contacts on the top and make sure that they are not covered by anything. Some come with a film to protect them.
Mar 10, 2008 | Sony PlayStation Portable (PSP) Console
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Toshiba Satellite P105-S6024 Notebook Logo
173 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
