Question about Canon LaserCLASS Fax 710 Printer
I have changed locations and am now using the Cable Company as my phone system and can't seem to get a dial tone on the fax or complete the sending of a fax. The phone line works for receiving and sending calls...I have tried both phone jacks on the fax and neither seems to work.
Anyone have a suggestion for what might be the problem and how to fix it?
Also, any suggestions on whether it's worth it to upgrade fax so it can serve as a printer?
  • Todd87 Feb 04, 2008
    Thank you....If you are familiar with this machine what would you charge to help me get this thing up and running for best use in home office to help with scanning, printing and multi-fax printing needs? I need to also reset the date and time on my machine.
    Send me an e-mail to sterlingtodd@earthlink.net
    President:
  • 4,402 Answers
Replace the line going into the jack, also try unpluging the power cord and plug it back in.
Posted on Feb 04, 2008
I need to change the date on the fax machine
Open all three one-touch dialing panels. Press [DATA REGISTRATION]. Press [Down] arrow until <5.TIMER SETTINGS> appears, then press [Set]. Press [Set] again for Date / Time Setting. Use numeric keypad to enter info.
Feb 10, 2010 | Canon LaserCLASS Fax 710 Printer
Fax will not always come in
Hi!
maybe you have wrong settings in to your  FAX Unit! just make sure the network is in good condition!
Nov 01, 2007 | Canon LaserCLASS Fax 710 Printer
No dial tone
plug out the fax... plug in a phone... if still no dialtone... replace phone cable... still no dial tone... call the phone company...
plug out the fax... plug in phone... dial tone heard... bad fax... try to reset fax machine... per instructions... still no dial tone... call repair guy...
Dec 18, 2009 | Office Equipment & Supplies
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
I have a 2050P fax and it has not been receiving faxes for a week. Is could it just be programmed incorrectly?
Make sure the phone line is plugged in correctly...ie. into LINE not PHONE. Facsimile machines will recieve , normally, without "programming" for sending number or company name. You can also check to see if the line is active by pressing the on hook button for a dial tone.
Jul 20, 2009 | Canon LaserClass 2050 Plain Paper Fax
Mailbox error?
This mailbox feature on the otherend doesn't make any sense. try dialing the fax number again and this time press the PAUSE button after the fax number and see. There is not enough info on your problem
Apr 06, 2009 | Canon LaserClass 7000 Plain Paper Fax
My fax machine will send, but it has no dial tone.
you should try replacing the cable between the fax machine and wall socket.
Dec 02, 2008 | Canon LaserClass 9000L Plain Paper Fax
710 Fax - how do I set up Group Dial?
Reprogram the machine. Have the machine serviced, and check the battery that holds information when power is lost
Jun 09, 2008 | Canon LaserCLASS Fax 710 Printer
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
How to Add Speed Dial Numbers -- Can't find menu
The easiest way is to use the intranet interface. Enter the IP address of the fax machine into your web browser on your computer (on the same network) and you will get the interface. Select the administrator role (hopefully the password will still be blank), and then go to the address section. You can enter speed dial numbers there.
Canon LaserCLASS Fax 710 Printer Logo
78 people viewed this question
old marine
old marine
