Question about Hoover U5444-900 5100 Wind Tunnel 15 Inch Wide Hepa Filter Bagged Black VacuumVacuum
Hoover doesn't suck well
My hoover windtunnel Mach 6.1 doesnt suck small particles anymore. Or sometimes it does suck up particles but then drops them off in other places. I even replaced the bag and made sure the hose was clean as well as under the vacuum. Any suggestions?
    President:
  • 1,673 Answers
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Posted on Feb 05, 2008
Hoover not sucking up seems to be clocked barrel not turning
Posted on May 29, 2013
Mach 2.1 bag?
Hello! The U6437900 takes Genuine Hoover Type Y bags. Follow the link to place an order for replacement.
Type Allergen Bag 3 pack
Jun 25, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
On our Hoover U6445-900 (Mach 6.9) we replaced the small belt that goes to beater brushes in front of unit. Upon starting, the Hoover quickly got hot and smoky. We shut it off and looked things over...
are you sure you purchased the right size belt..the friction you speak of is usually caused by a belt not being the right tightness or a jammed beater brush
Dec 19, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Not Sucking!
If you have the instruction manual check for how your vac breaks apart. It sounds like you may have to follow and break away all parts until you find the blockage. I am assuming you have full power in your motor .
Aug 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Is there a manual for the hoover windtunnel Mach 3.8? thanks
if you go to hoover.com and look under download manuels. when it asks you for the model num. for your machine, put it in and push enter/search. if it's the pic. that i see and model num. U6437-900, you will need to put U6439-900 instead.( when putting in the model num. you don't have to put the dash in) i've checked for you and your model num. doesn't show, but the one that i have provided will be almost the same one has yours, but maybe a color difference and some tools extra. the manuel should work for you though. hope this helps
Aug 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
New main belt alignment for Hoover Windtunnel Mach 6.1. Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853508
Generic problem for all Vacuums
Posted by donlee300 on July 29, 2008
Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you may have a broken or cracked motor mount and the motor has shifted and that could be the reason that the belt is not running straight and aligned properly – if you have the vacuum less than one year – something like this would be covered under the Hoover factory warranty and to contact an authorized Hoover vacuum cleaner dealer in your area or to call the Hoover factory cust serv @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
I purchased a hoover windtunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=724091
I purchased a Hoover WindTunnel
Posted by billmar082 on Jun 30, 2008
I purchased a Hoover WindTunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the particles but the filter will not turn. I also haven't been able to use the pet brush for some time. The cleaner has not been used hard about once a week since it was purchased. I am not happy that this product has stopped working efficiently since purchased 6 months ago. Thank you Marcia Long Pottstown Pa
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I sorry you are having a problem with the Hoover WindTunnel Vacuum Model #U8361-900 but I never heard of a filter that you say is self cleaning and NOT turning. I have never seen a filter that turns inside the chamber, the dust and dirt basically go around and circulate around the filter and you can clean the filter by either brushing it off, vacuuming it off or using some type of brush to clean off the filter such as and old paint brush or if you have some type of blower system – that would work as well. You said your vacuum is less than one year old so I would contact your local factory authorized Hoover dealer in your area or to cal the cust serv @ the Hoover factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
When sucking up dirt I can feel it hitting my feet
You could have a partial clog eihter in the hose or in the dirt inlet by the brush roll. If can't figure it out, you have a years warranty on this, take it to a warranty repair shop.
Mar 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5444-900 5100 Wind Tunnel 15 Inch Wide Hepa Filter Bagged Black VacuumVacuum Logo
727 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
