Question about Samsung HL-R5078W 50" HDTV
Lower left quadrant has shadow
After tripping and falling against the TV stand (ouch) my set now has a permanent shadow on the lower left quadrant of the screen and a dot of what appears to be a reflection near the center of the screen on the edge of the shadow. The projector lense was cleaned, but the shadow remains. The repair guy says it is "the light engine", but I have my doubts. The estimated cost of replacement is $1500.00.
  • Benjamin Fordham Mar 04, 2008
    After contacting a Samsung service center and being told they had no idea what I was talking about, I challenged a local repair man to try and replace the light tunnel. He agreed and I bought the part for about $75. He replaced it ( along with a new color wheel which cost $150 and a new lamp which I had already purchased) Total cost for me $358.73. This is a far cry from the $1500.00 estimated by the Sears service guy. Thanks for the education! All is well. The shadow is gone, the picture bright as new again.
  • 113 Answers
By knocking into the tv you have shifted the light tunnel in the light engine. The repair for this is to replace the light engine the part number is BP96-01198B you can order it from Samsung parts.com The cost for the part is 985 dollars but if you return the one the repair man takes out you get a core credit of 350 making the light engine only 630 dollars or so...You should be able to find a repair shop to put this in for labor of less than 300 maybe even 250...our shop does a Samsung for 190 Labor. Hope this helps.
Posted on Feb 05, 2008
I have a Vizio E470i-ao smart TV. On the left hand side mostly bottom left corner it dims out every two seconds and then returns to normal after two seconds. Constant pattern like a neon sign blinking....
Its likely the power supply. They are notorious for problems. The backlight is powered in quadrants. Your lower left quadrant is failing. I love fixing things but Vizio is nothing but trouble. I wont even work on them they are so poor to repair.
If you are handy, check the power supply for the backlight for bad solder. If it looks ok, then Id use it until it goes bad again.
Dec 25, 2017 | Vizio Televison & Video
How do i fix the shadow on my Samsung TV?
Well, it has a bad T-con board. You'll have to pay for the part, but you can fix it yourself. The board can be replaced easily. The T-Con board is usually near the center of the screen when you have the back removed. Just look at the ***** holes with arrows pointing to them and take out only those screws. Once the back is off, you'll see a board under a metal cover(not always) The board has flat wide ribbon cables that go to the bottom of the screen. Get the numbers off the board and go here for parts: TV Parts Universal TV Stands DLP Chips ShopJimmy
Mar 18, 2016 | Samsung LN32A330 32 in. LCD TV
Re set the time on my 43-3829
The instructions are in the "setting the day and time" section in the lower left quadrant of the first page of the downloadable manual at
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303829_PM_EN.pdf
May 07, 2011 | Radio Shack (43-3829) Digital Answering...
How to set time
The "setting the day and time" section is in the lower-left quadrant of the first page of the manual at
Jan 20, 2011 | Radio Shack (43-3829) Digital Answering...
I have a convergence problem in the bottom of the lower left quadrant pf the screen. It is like a parabolic semi circle that is at the very bottom edge of the screen. The front screen isn't damaged at...
Tv 100% have a convergence problems,if any parts of the tv picture colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board the 2 STK ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Westinghouse HD Flat Screen 1080Pure TV - Shadows
Image burn can be permanent if the image was left on for a long period of time. You can try a pure white screen to balance the screen out. They sell DVDs online that have white screen and other screen correcting images to try an correct the damage done to your panel. here is one linked plasma or LCD both can burn.
best of luck
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 14, 2010 | Televison & Video
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Choose four digits, all different, and place them in a 2x2 grid so that the numbers across and down total 200. How do I do it?
A two by two grid forms four quadrants. In the upper left quadrant, place a 4. In the upper right quadrant place a 2. In the lower left quadrant, place an eight. In the lower right quadrant place a 5. Horizontally, the numbers 42 and 85 are formed. Vertically, you form the numbers 48 and 25. The sum total of these numbers is 200. 42 + 85 + 48 + 25 = 200.
Nov 11, 2009 | Mathsoft StudyWorks! Middle School Deluxe...
Screen problem
I think try going to display setting under control panel. See if it allows you to change to full screen mode.
Sep 17, 2008 | Compaq Presario X1000 Notebook
Samsung HL-R5078W 50" HDTV Logo
151 people viewed this question
Jerry Greenberg
Jerry Greenberg
