Question about JVC COMPACT VHS-C CAMCORDER
Tape eating I have had my camcorder since 2001 and had no problems until now. It has started eating my tape, whether I am taping or trying to replay. It happens shortly after the tape starts. Is there any solution I can do or does it require a repairman?
  • Anonymous May 15, 2008
    After tape is inserted, I get a message to remove the tape and the tape is unwound and stuck in the unit
  • Anonymous Oct 30, 2008
    my camcorder is eating the tape!!!!!!!!!!!!!!!!!
My camcorder eats the tape and i have alot of tapes that i recorded on it and i can't see them any where else.and no body fix camcorders in my area what can i do?
Posted on Jul 11, 2008
    President:
  • 4,402 Answers
Unit need to be cleaned or have parts replaced if they got bad enough.
only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
Posted on Feb 07, 2008
6ya staff
SOURCE:
Camcorder is eating tapes (or tapes are getting stuck)
Hi ; this problem is a miss alignement off your tapthern and you may replace the pinch roler assy
and a good head cleen up
and that should solved the problem garanty
hope thats will help have a nice day
Mar 04, 2010 | Canon ZR10 Mini DV Digital Camcorder
Camcorder eating tapes
Your problem is a plastic belt that drives take up and supply reel. Most likely, you will not be able to relace it by yourself.
Dec 02, 2009 | JVC GR-AXM17U Camcorder
Samsung Camcorder eating tapes
the roller inside your camcorder might have dust dirt. try to use camcorder's tape cleaner to clean it.
Jun 28, 2009 | Samsung SC-L906 Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
JVC gr-axm310u tape eater
you know what it could be a malfuntion in the circiut take it to future shop or something
Jan 07, 2009 | JVC COMPACT VHS-C CAMCORDER
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the motor.so remoce the mechanisum and fix with a new one.
Oct 20, 2008 | JVC COMPACT VHS-C CAMCORDER
Eats tapes!!
Try using a DV tape cleaner to clean the tape heads first and see if that makes a difference.
Sep 26, 2008 | Canon ZR10 Mini DV Digital Camcorder
Canon ZR200 camcorder
mechanical problem. maybe the capstan motor is not running
Aug 08, 2007 | Canon ZR200 Mini DV Digital Camcorder
R 0:00 -- can't play back tape
try to clean the video head...i advise to use a blank tape and fastforward it until the time code counter display...you should on it the menu of the camera..
Aug 05, 2007 | Panasonic PV-GS500 Camcorder
There is no voice when I replayed the camcorders
What happens to the audio when you play the tape in another machine? Does it still drop out? Check the tape visually when it has no sound and see if the edge of the tape is creased. Also is the picture OK when the sound goes off. Does it jump around ans lose sync. If it does it means that the tape is mistracking. It's possible for the tape guides to go out of alignment but usually this is accompanied by picture breakup too. If you've never done it before don't attempt to realign the guides youself, you can really put it out of alighnment and it will damage the tape. Is the microphone built in or removeable? if it's the latter then check the connections and make sure nothing's broken. If there's a switch to go from internal mic to external mic see if it's switched to the proper position, it could be half way between internal and external. I'm opting for a tape problem, Either way a trip to a repair shop may be the best bet. BMW
Jun 02, 2006 | Sony Handycam DCR-TRV22 Mini DV Digital...
Video Cameras Logo
746 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
