Question about Apple iMac Blueberry Mac Desktop
I want incoming calls to disconnect modem
I setup an old iMac G3 for my mildly autistic nephew to blog with. My sister has a dial-up connection for him and no calling waiting on her phone line. I've set the modem to never disconnect when idle as my sister requested. She's still having one problem with the dial-up setup in general. When she receives an incoming call, she actually wants the Internet connection to drop so she can take the call like her old WebTV did for her or at least know there was an incoming call. I don't see a setting anywhere for this and the only Google solutions I've found are to counter the behavior she is asking for with phone lines unlike hers that have call waiting.
Any suggestions will be greatly appreciated - whether with a built-in setting, Apple script, or third-party application. Thanks.
  • 2 more comments
  • darrelld
    darrelld Feb 07, 2008
    My sister's iMac is running OS X Tiger (10.4...). Thanks for the link, but that seems to refer to configuring a modem to allow for Remote Access with scripting. I found that in my search, too, but passed over it.
    After speaking again with my sister, she told me that I assumed incorrectly about her phone line. She actually does have call waiting, which usually interrupts connections for other Mac OS X users, but not her.
  • darrelld
    thespark - awesome! That makes sense to me. I'll hook her up with an external. Thanks!
    cammedic - thanks again for your input.
  • darrelld
    darrelld Mar 13, 2009
    Thanks thespark! That's the info I needed.
    Cammedic - your help is appreciated also.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    This might be helpful: Apple
    Beyond that, What OS is the iMac running?
  • 73 Answers
Resume call is a function of the modem...
Unless that G3s modem has a firmware update to allow this,
I think you are looking at a new external modem.
Look for V.92 on the box
Posted on Feb 07, 2008
  • B Helling Feb 07, 2008
    Oh yeah .. OMT... (one more thing..) Her phone service has to have call waiting... Most stndrd plans do ... Cheers and thanks..
Connecting an external monitor via the imac g3 vga port
The G3 iMac, to my knowledge, does not support an external monitor.
Nov 11, 2012 | Apple iMac G3 Desktop
Sometimes when the phone rings I loose internet services
Are you subscribe to a DSL service? If you are, make sure that you have a DSL Filter installed (see image below). Without this DSL filter, you will get disconnected when there's an in-comming call.
If you're on a dial-up connection, this is normal since your Telephone and modem share the same line thus disconnecting your Internet when there's an incomming call.
Sep 06, 2011 | Computers & Internet
Can't set up dial-up connection
Restart the computer.
Enter BIOS setup.
Click to "disable" both the COM1 and COM2 (or Serial1 and Serial 2) ports.
Save-and-exit from BIOS setup.
Restart Windows.
The modem should now be assigned as 'COM1', and should work.
Apr 17, 2010 | Arris SM56 (SM-56-PCI) Modem
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Super g3 fax says to load paper, but the paper is loaded. Is there a fix?
Hello i uesed the dial up modem I Have all window driver but I wantan to modem dirver for win vista
dial up modem
Mar 11, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Possible modem problem
Make sure you log on details are correct. Confirm the dial out credentials. The line just needs a dial tone, which you can test with a land line phone.
Aug 01, 2008 | Apple iBook G3 Mac Notebook
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Aug 18, 2007 | Belkin (F5D7231UK4) Wireless Router
Apple iMac Blueberry Mac Desktop Logo
87 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
