Question about Whirlpool GU2400XTP Built-in Dishwasher
Odor will not go away.............
I burned a plastic spatula on the bottom..( only a small section of it)....I cleaned it all up and everytime I use my dishwasher, I smell an odor that is a "HOT" smell..........my whole house smells now like this odor.......I have ran my dishwasher empty several times....... Thanks!!! I did try lemon juice and I tried baking soda......didn't help!!! I have the same problem. I too dropped a spoon in the bottom of my dishwasher which melted a small section of the handle. The smell was horrific. Now I every time I run my dishwasher I have this smell and to make matters worse, even my dishes have this smell. I have tried baking soda twice, even letting a bowl of it set overnight. I have tried Dishwasher Magic, and a whole bottle of vinegar, no luck so far. Does anyone have a solution?
  • 1 more comment
  • Maggie Ann Feb 07, 2008
    Thanks for the suggestion, it helped a little but you can still smell it quite a bit. Thank you.
  • Anonymous Mar 25, 2014
    How do I clean the filter? Maybe there's food in there causing the smell.
  • Brian Williams
    Brian Williams Nov 18, 2017
    This sounds like you will need to remove the sump which is located under the machine , it is best to take the machine completely out and put it on a table , this will make it much more easy to do .The sump will probably have oil and food particles which will need to be removed also check the drain hose making sure it is clean as well .
  • 871 Answers
i would let you try putting a small can with charcoal in it inside the dishwasher. However, you cant use it for about 1 weeks' time.
Charcoal absorbs trapped smell.
hope this helps.
Posted on Feb 04, 2008
6ya staff
SOURCE:
Why suddenly a strong odor of burning fuel when heater is operating?
Improper air to fuel mixture, way to rich.
Does this heater have the ability to adjust ratio?
if so, play with adjustment until odor goes away.
Mar 25, 2015 | DynaGloDelux Dyna Glo Delux Liquid Propane...
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
Used our humidifier last winter, cleaned it, dryed it, and put it away. took it out to use it and it was a little dusty, so i cleaned and dryed it again, but for some reason it wont work. when you turn the...
If it smells like plastic burning. Stop using it immediately. As there could be an electrical short or overheating of the unit. If doesn't smell like plastic burning, you'll need to be more descriptive of what the odor smells like.
Feb 09, 2011 | Hunter 33201 Humidifier
A rubber spatula was dropped to the bottom during the wash cycle. It melted a small hole in the bottom of the washer, and now it's leaking. Is there a way to patch the hole?
High-temperature silicon glue will probably work ok. Be sure to clean the hole with alcohol and allow 24 hours for the glue to cure. Epoxy would be a better seal, but it doesn't adhere to plastic very well. Hope this helps!
Sep 22, 2010 | Kenmore Dishwashers
What causes the pungent odor in dishwasher? It seems that the all the water are not being dried
Hi, this is a very common problem and can be sorted out easily, rather than explain it here i include some weblinks that explain it all in detail. plus my favorite below.
http://www.ehow.com/how_2330730_remove-odor-from-dishwasher-.html
http://www.mrscleanusa.com/en/cleaning-tips/kitchen/clean-dishwasher.html
Here is one that takes the smells, hard water stains etc out of your dishwasher and plastic and glass ware. Fill up dishwasher, with plastic glasses, glass ware, dishware. No metal, of any kind! anything you want sparkly and clean.
No detergent! Fill up a small bowl at the Bottom of the dishwasher with vinegar, 1 cup of white. Run the cycle, do not dry. Fill up with 1 cup of bleach, run again. This takes care of all hard water stains, germs that are causing smell etc. Also check for food at the bottom of the dishwasher.
The site below explains WHY you get those smells.
http://www.doityourself.com/stry/what-causes-dishwasher-odor
Aug 19, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
I have an oder in my fridge and freezer. no spoilage in there. both the fridge and freezer has an odor and gets into all the food. cleaned it out, shut it off for a day and still i have it. would would...
ok.its a very common issue.just tie a handful of baking soda in a soft cloth and keep such1 or 2 pads in both the freezer and fridge section.this will absorb all the bad odor within a day or two.once the odor is gone throw the pas away.repeat this once in three months to prevent the bad odor from coming again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Amana ABB1927DE Bottom Freezer...
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
Bad odor in freezer
the only source for odor in a refrig is from food. check to be sure that nothing has gone bad in the refrig section as well as air circulates back from the fresh food section as well as the freezer. if you stil cant find odor source try charcoal or unscented kitty litter in a small container to help remove bad odors..
Dec 12, 2007 | GE GSS25JEMWW Side by Side
Whirlpool GU2400XTP Built-in Dishwasher Logo
553 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
