Question about Motorola Mobility MPx220
The screen of my motorola shakes
The screen of my motorola is shaking and I can not see any thing on the screen . But it do receive calls
  • edmflo Apr 03, 2008
    The solution has been very helpful. I will visit a local technician and ask them to do exactly as you advised.
    I will get back to you when it is fixed
    Thanks,
    edmflo
    Novelist:
  • 119 Answers
Dear edmflo,
This sounds as a hardware error. Since this is a flip phone the strain ussually is inflicted at the flex cable connecting the Motherboard to the LCD screen. This is a very fragile piece of equipment (chaep though around 5-15$ at ebay) and breaks easily even after normal usage.
If it is not broken it also simply loose at the connectors. Attaching it again will solve the problem.
At this point I believe that the possibility of an LCD that is defective is less than 5-10%.
Regards.
Posted on Mar 31, 2008
I have a problem with disc brakes, 5-6days to destroy them and the car shakes ... why?
car shakes which is called shimmy shake,if brake pads been replaced wheels still shimmy, you have worn brake rotors with low and high spots,you could have bad wheel bearing, you have worn out tie rod ends and worn out ball joints,you could have tire out of balance,also you could need front end alignment.many things will cause wheels to do the shimmy shake.
Apr 07, 2011 | 2004 Jaguar X-Type
My Samsung T.V screen is constantly shaking at very low rate.I have recently bought Airtel DTH & i assume that after that my T.V started this problem.I am not sure about it,because when i detached DTH...
I have that problem with my Samsung TV!!! I unplugged every input and just used the TV through Internet TV and the screen still shakes. I have had the digital board replaced and that just made it worse
Sep 14, 2010 | Televison & Video
TV picture is shaking up and down.
Try unplugging any devices near the TV one by one and see if that helps.
I had the same problem with my picture shaking on all HD channels and found that it was my land line phone interfering with the signal.
Hope that helps!
Dec 11, 2009 | Samsung LN46B640 LCD TV
The bottom half of my screen is shaking like a "non" TV channel.... I restarted it, and turned it off and back on again and it continued. The shaking occurs every 2 seconds and is spreading higher now. ...
If you can.. Plug a Desktop Monitor into the Serial Port of the Laptop..You do This To See If It Shows Same Thing Onto A Different Screen.. If It Does, You Are Having Video Issues.. Which Were Most Likely Caused From Overheating Issues..
If It Shows Normal On The External Monitor, Yet Still Does Same THing On The Laptops Screen, Then You Have 1 of 2 Issues... Either You Need To Replace The Display Due To A Faulty Circuit Board On The Backside Of The Screen... Or Your Display Cable Is Loose And Needs To Be Fully Plugged Into It's Port, Or The Display Cable Is Failing..
Nov 15, 2009 | Computers & Internet
When somebody is calling me theres nothing appearing on the screen what will i do
If you have a protective screen on the phone take it off.
If this works replace the screen below the LG logo this way it doesn't cover the sensor on the left hand side.
Sep 27, 2009 | LG KM900 Arena Cell Phone
N72 display is shaking
Could be an issue with the battery. As it might not be providing enough voltage to the phone.
Change the battery and check if it helps.
Sep 09, 2009 | Nokia N72 Cellular Phone
My 755 won't turn on sticks on verison screen
okay i think i know how to solve this because it also happened to me.. okay first take the battery out and see if there is a red dot on the battery
RED DOT--- okay if there is a red dot then it got wet. thats how it died. take it to the Verizon store and they can fix it
NO Red DOT-- okay this means that you DID NOT get it wet. take the battery out and shake it ( i know it sounds silly but trust me on this), After you shake it put it back in the phone and shake the phone. it should work.
AND IF ALL OF THESE DIDN'T WORK... then go to the verizon store a get a new battery.
Jan 11, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Nintendo ds
I have a similar problem with my bottom screen. when I started using it it was fine, but then it started to shake. calibrating it didn't do anything. and what's weird is that the screen only shakes in the nintendo ds menu. it doesn't shake during games. and it still works just fine technically, just...shakes...during things like pictochat and startup. weird...
Aug 31, 2008 | Nintendo DS Console
Picture Shaking
Do you have any big speakers or some other appliance near the TV?
Magnetic fields make the screen images 'shake'.
Dec 09, 2007 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Call Divert wont go off!
Hi guys
That call divert comes automatically, did my nuts in today. Anyway just key this code
#002# , then press the green key, then bingo call divert off.
cheers
Irwin
Nov 12, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility MPx220 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
