Question about Akai CF2791 27" TV
On/Off switch I have to turn my TV on and off about 20 times before it will stay on.
  • 1 more comment
  • Walk33a Feb 05, 2008
    I bought it new 4 years ago.
  • rogshark May 28, 2008
    the tv works fine but will not turn on. when the power is turned on with the remote power switch or by tv on/off switch, the green power light will come on for a few seconds then switch off. I can repeat this ten or so times until the tv finally stays on. is theis the same problem that can be solve with a new power unit and where can i get one?
  • Anonymous May 11, 2010
    hoii? (how old is it)
  • 682 Answers
Change power on-off switch. first try to apply contact cleaner from nearest(radio shack).if it is solved it is fine -if not you must change power switch.
Posted on Mar 08, 2008
6ya staff
SOURCE:
Agora tv switches off after 20 min
my 32in tv some time turns on and some time not, the blue stad bhy light is on. when we do get it on yhe tv only stays on for 20 min and then goes off . please help
Jun 20, 2012 | Mitsubishi WD Televison & Video
Need the remote se up coed for Panasonic tv.vcr combo model PV-2061. The nine 5 digit codes provided by Comcast do not work
Hello
Just try with these four digit codes
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your combo with its FRONT PANEL POWER SWITCH EACH TIME before trying an other code. OK.
Feb 17, 2011 | Panasonic PV-C2061 20 in. TV/VCR Combo
What was the code did all work cause i can not get it to work at all
Hello
Just try one amoung the following codes. I've only these three codes are available with me for Jensen Tv.
{ 0004 _0009 _0133 }
Proceedings
Note:- If one amoung the above four codes did't work, try the other after the TV is switched off and switch in again after some time, say at about 10 seconds, and try the other. Not enter the code continously without turning it off, after one code won't work. Ok.
__________________________________________________________________________________
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Oct 25, 2010 | Jensen TS2050J 20" TV
My tv turns off all the time
You may have an issue with the power supply. Check the circuit for loose connections or solders or leaking capacitors that may need replacement.
Sep 02, 2009 | Orion PK-8420 84 in. Plasma TV
When I turn my TV on, it clicks on and off 5 times then stays off
first check a switch contacts, that switch has two make contacts in side it. if the switch is okay, then check a power supply dry joints on it.
or a dry joint on the line out put transistor, or a line transformer legs.
Apr 30, 2009 | RCA F27450 27" TV
Broken television?
try to re solder your tv.,coz mostly the defect of tv. is only a lose connection., but be care of short circuit
Sep 10, 2008 | Sanyo DS20930 20" TV
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
Akai CF2791 27" TV Logo
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
