Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
My husband has tried all the advice but to no avail. The dishwasher has been pulled out but it won't drain. The intake/drain light is still flashing, Could it be plugged inside the dishwasher?
  • 5 more comments
  • Anonymous Mar 01, 2008
    this unit just sucks.
  • Anonymous Mar 06, 2008
    I have the same problem.
  • Karstinky Apr 09, 2008
    Water is left at the bottom of the dishwasher and the intake light is on. The dishwasher won't run a cycle.
  • trinitymadai May 18, 2008
    When I searched the net for the solution to this problem, I remembered that it had happened once before. (My machine is 5 years old. This is only the 2nd time.)
    I read these comments and looked for the owner's manual I had saved on my computer. (It's in PDF format.)
    It tells exactly how I fixed it before, by clearing the valve.
    Unfortunately, my hands are much weaker now, due to a computer injury (repetitive stress), so I don't have the strength in my fingers to pull the valve out this time. I'll have to get someone else to do it for me. But I do remember that this works.
  • Anonymous Apr 18, 2009
    Intake light is on (red)
  • Gary Davd
    Gary Davd May 11, 2010
    have you open the pump section like it shows in the User guide?? One last thing have you had a new disposal install recently??
  • Anonymous Mar 28, 2014
    I fixed myself last year on the impeller motor in the bottom. It wasn't moving.
  • 9 Answers
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Posted on Apr 20, 2008
  • 3 Answers
This happens to me occasionally. There is a long thin bottom panel along the floor. Then there is another panel behind it. Behind, there is a pan that holds water. If too much water gets in that pan the intake/drain light comes on. Take those two panels off, feel in the pan, if there is water pooled, then wet vacuum the pan dry. That solved my problem and saved me about $200. I got that info from the miele advisors. That is what it is about 90% of the time if it isn't that intake valve.
Posted on Aug 14, 2009
  • mjlsop Sep 30, 2010
    If you are using too much or the wrong kind of soap, it will bubble up and water will end up in the pan. I had a long chat with a Miele guy, and since have used ONE TABLESPOON ONLY of Cascade (I measure) and have never had any water in the pan again. I had been using Seventh Generation some, and too much soap all the time, both no-no's.
  • 3,230 Answers
Well first of all you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
Good Luck!!
Posted on Mar 27, 2010
Just had the same problem, cleared the drain pump, the filter on the water inlet, etc. Finally called Miele and they suggested connecting a wet/dry vac to the drain hose and **** out whatever was clogging the drain hose. Worked like a charm.
Posted on Apr 08, 2010
I have the same dishwasher and it will not INTAKE water. This unit does ****. So much for a "smart dishwasher".
Posted on Apr 07, 2008
I had the same problem. Finally, Miele came in and put in a new part and it has been working fine. And he looked at my installation and gave me this advice and I don't know if it is applicable to any of you.
Miele dishwasher has always been using a 3/4" drainage hose. Most if not all, North American made dishwasher only require a 1/2" drainage. If you have switched from an American made dishwasher, your installer may just rigged it by "padding" the drainage hose to fit onto the 1/2" drainage pipe that was in place. If he is doing a proper job, he would have to change the drainage pipe to accommodate the 3/4" drainage hose.
My guy did not change it. Miele dishwasher is designed to drain within some time frame (think 20 or 30 seconds). When it is draining into a 1/2" pipe, it got slows down. It was like fit in a pair of pants that is half a size smaller than what you should wear, it will take time to squeeze in it. He feel that in the long run, that could have caused this little problem we are facing here.
Posted on Oct 10, 2008
  • 3 Answers
I had a similar problem. Over the past few days I have been finding a small pool of water left in the morning (like it didn't drain enough). Today I found a massive pool and the inlet/outlet light was solid. After hand draining and trying stuff -- no luck. Finally decided to get old-fashioned, and just took the bathroom plunger and plunged the thing for a minute or two. At first it wasn't doing much, then at some point i could hear the water flow out!! It must have been some debris blocking the outlet. The plunger worked a charm - and all is perfectly fine now! Thought I would share. Good luck!
Posted on May 31, 2015
    New Friend:
Good advice, Mukesh.
After removing the triple filter, scooping out the pool of water, and checking the drain pump (round plastic tube beneath the wire) to make sure the propeller spun freely, the light was still blinking.
What reset it for me was to (1) turn the rotary dial to "Stop", and (2) press and hold the "Start" button for ~5 seconds.
When I turned the rotary dial to "Normal" wash, the Intake/Drain light stopped blinking, the machine drained, and resumed its wash cycle.
Miele should have this basic troubleshooting info on its website or in its manuals (or both!).
Posted on Oct 19, 2014
I had the same problem with the flashing water intake light. Last night the main water line in the street ruptured and we all had our water turned off. When I tried to run the dishwasher today, after the water was restored, that light started flashing when I turned the dishwasher on. I think what the problem was air in the line. I remedied it by repeatedly turning the dishwasher on and it would fault out until the air was cleared out of the line. Thank goodness that's all it was. It's running fine right now.
Posted on Oct 25, 2011
SOURCE:
The intake light comes on and the machine will not go thru cycle, it just hums.Water does not drain.
its obvious the drain pumps blocked, rempty machine, remove drain plug, wire mesh scoop water in middle, then take off the plastic cover with a steel like wire on it, clear out the **** blocking the pump, assemble then should be ok.
Jun 14, 2011 | Miele 23 in. Novotronic G841 Built-In...
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
My Miele Platnum dishwasher is not working. It is flashing "intake/drain" When it begins instead of the normal hearing of water moving around you just hear a humming. My husband and father took out all the...
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 03, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele Intake/Drain light on/flashing and the dishwasher just shuts down.
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
Nov 22, 2009 | Miele 23 in. Novotronic G841 Built-In...
Intake/drain light on
Aug 13, 2009 | Miele 23 in. Novotronic G841 Built-In...
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
May 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
Intake Drain Light
My Miele Incognito dishwasher kept getting an error with intake/drain light. The light flashed 5 times. Phoned Miele Technical Support to investigate the problem. The problem is that a seal in the bottom of the dishwasher has failed and there was water in the motor pan. Currently, $175 service charge for the technician to come look at it.
I don't want to spend $175+ to have them replace a 75 cent rubber gasket that I could replace on my own.
Feb 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
24,066 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
