Question about Brother HL 1230 Laser Printer
Problem with the printer
My printer is connected to the network and when i try to print a page it is not printing stating that an error is there .When i tried to print locally the printer printed the page.There is also a TICK mark beside the printer icon .So what could be the problem
  • 417 Answers
Hi there the TICK mark just means that it is your default printer. Do you know the IP address for your printer if so follow instructions below.
  • Press Start
  • Select Run
  • Type CMD then press enter
  • Screen will open type the following " ping xxx.xxx.xxx.xxx" then press enter (xxx = IP numbers i.e 192.168.42.1)
  • If reply getting there is nothing wrong with network. If not right hand click on the printer icon and select properties.
  • Select Ports as check that the port is the same for the IP address.
  • If not add new port Standard TCP/IP follow on screen instructions.
  • Try changing the network cable.
Hope this helps
Thanks J
Posted on Feb 04, 2008
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Printing blank pages
I am assuming that the printer is connected to a network. Please check the network cables to make sure they are secured, and then try printing the network setup page. The network setup page will show status connected. If the status is not connected, contact your system support person to make sure the network is functioning correctly
Before sending a job to print, make sure the printer is set to ready state. Ready or Power Saver appears on the display. Please check the status of the toner and check that you are using the correct printer driver.
Printer driver is available on the Lexmark website for download. If no fix, for other information please click the link http://bit.ly/k2p8B5
For additional assistance, please contact Lexmark technical support.
Jun 20, 2011 | Lexmark X658DE All-In-One Laser Printer
900 service rip software
The 900 error usually indicates a software or communications problem. If the 900 error occurs only when the printer is receiving information from a network or computer, you should contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer.
To check the base printer
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer
May 05, 2011 | Lexmark Optra T610 Laser Printer
900 service RIP software error - how do you fix it?
Please try to do the following steps. Remove parallel, USB, and/or network connections andrecycle the printer's power so that it is operating as a standalone machine. If it powers up to the Ready state, print the MenuSettings page(s) from the Utilities Menu. If the printer works without error while disconnectedeither from the network or a locally attached computer, there is a strong possibilitythat a corrupted file or network/parallel/USB connection is causing theerror. Look for patterns such as aparticular file or a particular workstation generating the error when data issent to the printer. Clear the print queue and connect all cables back andturn the printer back on. Resubmit the print job(s) and try printing again b> If the error will not clear, please take note of thesecondary code and contact Lexmark Technical Support.
Feb 07, 2011 | Lexmark T522 Laser Printer
Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Jul 03, 2009 | HP LaserJet 1022 Printer
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
Printer FREEZES and prints blank pages
I DON'T THINK ITS THE PRINTER. THIS IS A SOFTWARE OR NETWORK ISSUE.
1 IT SOUNDS LIKE CORRUPTED FILES BEING SENT TO PRINTER, OFTEN PDFS. CLEARED ALL PRINT JOBS? ALSO AS400 PRINT QUEUE?
2 ALSO SOUNDS LIKE A VIRUS POSSIBLY "Adot.BAT". go online to housecall.com and do online virus scan.
3 OR, SOME OTHER CHANGE OR NEW DEVICE ON THE NETWORK MIGHT BE INTERFERING.
FIRST, TRY ISOLATING THE PRINTER FROM YOUR NETWORK. UNPLUG THE PRINTER FROM ALL DATA INPUTS AND RESTORE DEFAULTS. (LEFT OR RIGHT BUTTON TO SERVICE MENU, PUSH CHECK BUTTON, LEFT OR RIGHT TO RESTORE DEFAULTS, PUSH CHECK BUTTON).
IT SHOULD RESTART, THEN CALIBRATE. NEXT PRINT A CONFIGURATION PAGE FROM ITS MENUS, IF NOT TWO PAGES NET CARD IS DEAD.
IF OK SO FAR, TRY CONNECTING IT JUST TO A LAPTOP. USB ONLY THIS WAY, OR USE A NETWORK HUB, SEPARATE FROM YOUR NETWORK. INSTALL ANY OLD LASERJET DRIVER OR PRINTER ON THE LAPTOP JUST TO TEST IT.
IF ALL THIS WORKS, THE PRINTER IS FINE. BEFORE RECONNECTING THE PRINTER TO YOUR OFFICE COMPUTERS, FIX YOUR NETWORK & INTERNET OR VPN PROBLEMS.
THEN, DELETE ALL HP LASERJET PRINTERS & UNINSTALL ALL HP DRIVERS ON ALL NETWORKED COMPUTERS AND SERVER. (EXCEPT ZIPPED DOWNLOADED DRIVERS). START NEW HP PRINTER INSTALLATION COMPLETELY FROM ZERO. REINSTALL ONLY THE DRIVER YOU NEED. PCL5 IS RECOMMENDED.
Jun 13, 2008 | HP Color LaserJet 2600n Printer
Printing only test page
when you click on the print in Microsoft Word is the printer there, is it set as the default printer?
Try this:
 click on File
Print
right click on the printer
go to Properties
Set as default printer
Oct 25, 2007 | HP LaserJet 4 plus Printer
Brother HL 1230 Laser Printer Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
