Onkyo M-282 2-Channel Amplifier Logo
Anonymous Posted on Jan 06, 2010
7.1 preamp output
I have a kenwood vr 7070 THX select reciever with a 7.1 preamp output. my question is if i hook up the m-282 amp to that output for the 6th and 7th surround speakers will i have to get a seperate piece to adjust the volume for them.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
221
Points
Called onkyo and kenwood they explained in detail how to hook up.
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
On my kenwood VR-5900 twospeaker wires touched and the reciever clicked off now when you turn it on it comeson for a sec. then clicks and shuts off. none of the fuses inside areblown what could be the...
When the two wires touched the short overheated and blew the output transistor or transistors. The unit needs to be repaired or replaced. It only takes a momentary touch of the wires to blow the output transistor. It is not a fault of your particular amp. It is common to all Solid State amps. Tube amps that have output transformers are not susceptible to this problem. Always shut off the amp when connecting or disconnecting the wires.
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do...
A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
If your DP doesn't work on either I'd suspect something is wrong with IT.
I have the kenwood vr-7070 and i was wondering how i could connect my ipod touch to it, can you help me?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
1helpful
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
1helpful
There are many different "listening modes" integrated on my Kenwood VR-7070 6.1 channel receiver. But i only get both front speakers to work when in "mono" mode. Is there an easy fix?
There is not a "fix" for this selection, MONO is basically a single channel output so there is no seperation for various speakers like left or right which is a stereo effect, mono is like a single speaker sound so you are fortunate to have the sound from 2 speakers but they deliver the same sound.
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
1helpful
Im having a problem with my kenwood VR-7070 receiver.I have my DVD player hood up to it using an optical cable and s-video. The sound comes in digital sounds amazing but the souround sound music is so much...
No unfortunately this is the way movies are made. I know what you are feeling it is the most annoying thing ever. The only thing you can do is turn down all the surround speakers and turn up your center channel. the voices and talking are always output through the center channel. So you have to do a lot of messing around to get the best settings for you. I am an audiophile and I will never understand why they make the background sound/music in some scenes so much louder then any talking. Hope this helps if you have any other questions please let me know.
Thanks,
Lee
Reciever
Since Kenwood makes a lot of amps, I can't be specific. Check to see if speaker (A/B) is switched on. Make sure "mute" switch is off. If useing tuner, make sure to hook up AM/FM ant.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
