Question about Acer Aspire 5050-3242 Notebook
Laptop sounds alarm 30 seconds when turned on
My 5050 wont turn on at first touch of on off switch 4/5 goes sometimes and when it eventually comes on it sounds a loud alarm for about 30 seconds and asks you to choose an operating system and press enter before it goes to the windows logo. also taking ages to shut down sometimes not at all and have to turn off at on/off switch
  • 108 Answers
Your system has got Viruses. Better you Re-install the OS after formatting your Hard Drive. Your problem will be solved.
Posted on Feb 04, 2008
Tv wont turn on lights eventuely will turn blue for on but screen doesnt come on
Sounds like tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2014 | Televison & Video
Gemini 7200 car alarm replaced battery fob not working no tx to alarm. please help and many thanks. natec
The problem seems to be the key fob on these alarms goes out of sink with the alarm unit (thats if you have changed the battery and its not responding), but 7200/7300 have the ability to "self learn" the new frequency your key fob has changed to .I dont know why they change frequency but they do.I have had to do this a few times myself. if you have a manual for this alarm it tells you how to do it in there but you will need the round key that comes with the alarm that fits in the top of the alarm unit (siren). Anyway to do it : 1.using the key switch alarm off. 2. switch on again. 3. turn ignition for 1 second then off. 4. push the key fob.within 30 secs. 5. switch dim dip (6) back to off. if it dosent work repeat.(dim dips are in the siren where the wire goes in) and if the alarm goes of while your doing it dont worry but just try and be quick. Hope this helps. Chris 13.
Apr 14, 2011 | GPS
I have a problem with my MW512AU. Sometimes it drains after wash cycle, sometimes it doesn't. Sometimes the drain pump stays on when it goes through spin, but spin doesn't get up to fast speed. When it...
Hi just read your posting.This problem sounds like your control module is doing funny things.Does it show an error code at all and beep?What part of Australia are you in?There is a place in Melbourne that tests these modules.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
The car alarm goes off after I leave my car and
sounds like the hood alarm switch is not making proper contact with the hood, the alarm will not set properly, check the hood alignment
Oct 06, 2009 | 2004 Mercedes-Benz CLK-Class
When i turn on my laptop the alarm bleeps for about 20 seconds, then the alarm goes off also having trouble with the backspace and enter keys, plus the touch pad does not work. all this has roughly...
has the laptop been dropped or gotten soaked by some fluid. sounds like something has infiltrated down to the laptop motherboard. Time for a new laptop, or some shop time
Jul 11, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
Acer Aspire 5050-3242 Notebook Logo
374 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
