RCA 32" SDTV just purchased in July '07, now it will turn on but not off, you have to unlpug it, and there is no picture or sound. Is this somethins that is repairable? Also I believe my cats have gotten behind it in partially unlpugged the surge protector it was plugged into, could this have caused it? Thanks!!
  • 103 Answers
I doubt the cats caused the problem unless the plug was far enough out to make intermittent contact, possbily causing a power spike in the set. It's hard to say from here. However, if you are not getting any picture or sound, it could be as simple as having nothing plugged into the input the set is 'looking' at, such as A/V 1 not having anything connected to it, and the set it 'looking' for a signal there. If you're sure that's not it, then you'll need to have someone qualified to fix it to look at it.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
Have a rca, sdtv, 32", screen stopped working.
Nope, you have a bad part inside.
It's fix or replace time.
Jan 06, 2010 | Televison & Video
Turns off when u turn it on
You probably have a bad flyback transformer. This is a common problem for this set. A 32" is worth a check out fee.
Oct 13, 2009 | RCA F32650 32" TV
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
My RCA 32 ' SDTV TrueFlat doesn't come on
sounds like you have the parental lock on to lock the buttons on the tv and the remote look in your manual for the tv to see how to fix it and if you dont have it there should be one online
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
Tv powers on but light just blinks and no picture or volume
A blinking power light would indicate a problem on the chassis board located inside the tv. Possibly a failed flyback or other electronic component. Its not cost effective to repair when you can invest in new tv for the same cost as repairing the defective tv. I should also mentioned the danger of dyi troubleshooting of the components inside the tv. I do not recommend unless you are familiar with properly discharging the tube to avoid electrical shock.
Jul 25, 2009 | RCA F32650 32" TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
May 19, 2008 | RCA HD52W59 HDTV Projection Television
My 32in sdtv red power light,no pic no sound
your problem is likely to be in horizontal section of tv. please take the help of skilled tech. it is not a major problem but as you know that it is a high voltage device.
Oct 05, 2007 | RCA 32F531T 32" TV
No picture
I would pull the cover off to see if the tube and the board on the CRT are not damaged. If it looks ok, turn set on and observe if there is any activity visible at the neck of the CRT (light). Wehn a set with a large tube starts-up, it wil make a fuzzt crackle noise fro the high voltage charge in the tube. If non of this is happening, check main board for cracks. Unit is probably salvageable for point to point solder job, but as far aspart replacement for HV power supply, I would not do it. It is not cost effective.
Aug 01, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
