Question about Harman Kardon AVR 525 Receiver
Just shuts off
Lately, my 525 shuts off right after i turn it on. checked the cables and ok robert
  • DIEHARD1 Jun 27, 2008
    I had it happen a few times and just doing a factory reset (Surround Mode Group Selector + Tuner Mode Selector) cleared it but now even that doesn't stop it from turning off anymore.
    I have tried unplugging all the speakers and the problem remains. :(
    Now I have to find out how much it's going to cost to be repaired I guess.
  • jrock0012 Aug 12, 2008
    My harman kardon avr 525 shuts down right after I turn the system on, everything is disconnected from the receiver and the problem is still there. If anyone else had this problem and knows how much it is to fix let me know thanks....
    New Friend:
Hello, logic 7 and other functions send incorrect output to speakers and overload the internal amp. If you find the correct audio output function than it won't turn off even at high volumes. Start at a low volume and obtain the best output. The one that worked for me was digital in and DTS function. I used video one as the source that well not matter any source or all sources should work but try to go digital on as many devices as you can, and hook video into HDMI alternative input devices or directly into HDMI port on the tv. Audio out from tv it's much simpler.
Posted on Dec 27, 2015
    Scholar:
  • 103 Answers
Most likely the unit is detecting an internal problem with it's circuitry or problem with a speaker and is shutting itself off to prevent further damage. You can try disconnecting all the speakers and trying again. If it stays on, then you probably have a bad speaker or shorted wire somewhere. Connect them one at a time to find out which one. If the unit still shuts off, then you've got internal problems that require a professional Mr Fix it.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I cannot turn off the 09 chevy cobalt- I tried pusing the plunger as the manual asks, no luck, I also tried turning the steering wheel left and right with brakes on but the car is still on and the key will...
ok if the key does not turn off at all the cyclinder need the be replace and may still be under warranty. there is also a bulletin to replace it. Take it to the dealer
May 23, 2011 | 2009 Chevrolet Cobalt
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
How to adjust idle on bmw 525 tds,diesel
losen the bolts at the pump flange where it bolts to the engine block and rotate towards the engine about a 1/8 inch also adjust the linkage stop screw inwards no more than 1 1/2 turns
Jan 21, 2010 | 1995 BMW 5 Series
Starter won't turn, just one tick but no action, lights are strong, no other sound. Have not checked anything yet but does this sound like a starter? Car was driving fine but did notice car harder to start...
Ok, the first thing to check is the starter, yes. This is free to do, just remove the starter and take it to Autozone. They will connect it and test it to see if it is functioning correctly. The best part is you can purchase a new one right there if it is bad. If it is not the starter let me know and I will help with further diagnosis.
Sep 30, 2009 | 1995 Nissan Maxima
I have a 1989 chevy Blazer 4.3 auto 4x4 Turned off the blazer tried to restart it would not turn over the fuel system is ok it has a new fuel pump relay fuel pump and fuel filter cleaned out the battery...
check your coils if you pull a plug and put it back into the wire, turn over to see if spark, if not coils or dis. module. hope this helps you, thanks robert b.
Jun 24, 2009 | 1989 Chevrolet S-10 Blazer
1998 Ford Explorer Wont Start. :(
Only make right turns! Only kidding! Have you hit a bump lately? Ford uses an Inertia switch to cut off fuel flow when triggered.Have that checked and reset.
May 31, 2009 | 1998 Ford Explorer
With destop wont turn on
Robert was right make sure your computer is unplug from the power strip. now check the power supply cable to the mother board, then check the power cable to the harddrive, and then the DVD.once you put the power cable back into the computer you should get the power supply fan should come on, and the cpu fan should come on.
Next once you hit the on/off switch and green light should come on.
Jan 23, 2009 | Dell (9228C) 200-Watt Power Supply
Charging problems
check the battery cables for good connections. if ok check cables for excessive resistance
Dec 24, 2008 | 1986 Toyota Pickup 4WD
Harman Kardon AVR 525 Receiver Logo
409 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
