Question about Dell Dimension 4600 PC Desktop
System won't boot
The Dell Dimensoin 4600 won't boot.
No beeps... the Drive light is on constant green and the power light does not come on at all.
I have tried a new power supply and a new battery.
Any Ideas?
Thanks, Dwight
  • 1 more comment
  • Dwight007 Feb 04, 2008
    There is no power to the CD...
    The system never gets to the Bios even.
    The results are the same with the HD unpluged.
    I would expect an error message saying it can't find the hard drive but it never gets close to that far in the boot sequence.
    No beeps or buzzes... nothing spinning but the fans... The only clue seems to be the Hard Drive light comes on right away and nothing else happens...
    Thanks for you input,
    Dwight
    Good Idea,
    I will try the Bios Reset on the MB
    Thanks
    Good Idea,
    Thanks
    Scholar:
  • 80 Answers
Hi
As the power light doesnt come on, the comp is not getting any power. Pls reseat the cable tht goes from the motherboard to the power button inside and check if it is turning in. Otherwise the comp has to be serviced.
Posted on Feb 05, 2008
  • 108 Answers
Better you try with a bootable CD, if that works then check for your Hard Disk it might got faulty or crashed.
Posted on Feb 04, 2008
  • Satish Chandra Feb 04, 2008
    After getting the Input from you I can suggest you only one thing that reset the BIOS from motherboard if still the problem persists go to the Authorised technician because it needs a physical repair.
Why wont my xps 700 boot?
Not sure on the beep side but this is what the lights code refer too.
Ensure that all hard drive and CD/DVD drive cables are properly connected to the system board.
If there is an error message on the screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
If the operating system is attempting to boot from a device (such as the floppy drive or CD/DVD drive); check system setup to ensure the boot sequence is correct for the devices installed on your computer.
If the problem persists, contact Dell (see "Contacting Dell" in your Owner's Manual).
May 18, 2014 | Dell Computers & Internet
Dell demension 4600c power light ok, hard drive light not on
sounds like hard drive dead or your boot files corrupted and your hard drive has no input power. could be power unit weak or your hard drive could have died..they do wear out.
do you hear any fans spinning? there are fans to keep your pc cool. one big one for chasis and one small on over processor chip(heatsink). if the smaller fan(especially) does not spin then PC will not boot because chip will heat up and break if no fan. system will protect itself from this by not starting. open chasis and check if small fan is working. if not this is cheap fix. if it spins then hard drive or graphics card may be bad, which gets more expensive. shop will charge average of $75 dollars to analyze-just to tell you what is wrong, not to fix it.
Aug 27, 2012 | Dell Dimension 4600 PC Desktop
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
My dell 4600 Dimensions was working just fine. The system locked up and I had to power down. When I tried to restart the computer powered up but there was no boot sequence, no beeping nothing. The green...
if you're familiar on how to open the computer tower's cover, we need to open it.
before opening the cover, make sure all cables are disconnected from the back of the computer. and make sure that you drained the remaining power of the system.
after opening the computer tower's cover, try to locate the cmos battery. (it's a silver coin like battery), remove it from your computer. wait atleast 10 minutes before placing it back. then try to turn on the computer again.
to open the cover, here's the link for the diagram:
http://tinyurl.com/9ax7f
for the complete manual of the system:
http://tinyurl.com/aqzp3
Oct 01, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600 no monitor signal
Hey Tony,
If you haven't already: pull all pci cards:
If you pull the ram, and you get no beeps at post, it's likely the main board. Does the pc beep at all? with or without ram? If not, likely the main board. Sorry. Hope this helps...
Aug 17, 2009 | Dell Dimension 4600 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600c will not power up -- green power button lit -
i think it may not power supply problem.it may be ram memory problem.try this,remove your ram and clean it with cloth and restore back.
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
147 people viewed this question
Alun Cox
