Question about Toshiba 2060 Copier
A question about the feeder
Hi Checkitright,
Thank you for accepting me as your buddy!
After I saw your advice on the Toshiba Document Feeder, I guss you must be the expert to answer my question.
I don't know a lot about the technical details about the copy machine although I'm an electrical engineer trying to build a product sorter. So here comes my question:
The project is a automatic cutting and sorting machine. A continues strip of material is fed through an automatic cutter, which cuts it into sections in predetermined length (typically quarter inch by 3 inch). The piece then falls from the cutter and into one of 20 containers in a raw. Before the cutter makes the next cut, the containers are shifted by one unit-length such that the next piece will fall in to the next waiting container. The system repeats itself automatically and after each run the 20 containers will have one piece of material each.
A document sorter seems to me to be a good replacemnt to a custom made moving mechanism. If (1)the sorter can work/move horizontally without the existance of a copy machine and (2) there are simple ways (like hooking up two wires to a press button or providing a TTL signal) of letting the sorter moving 1 step at a time in either direction, I think this plan is feasible.
Is a typical sorter able to to that job? Or, based on your extensive experience on so many brands, sorters from a certain brand can fit the bill?
Please let me know if more information is needed.
PS. I have created a question in the Fixya forum and thought you might think that's more efficient way for communication. (http://www.fixya.com/support/t381923-feeder_work_without_copier)
Thanks!
mingliu
  • mingliu Feb 04, 2008
    Hi Checkitright,
    Thanks for the comments!
    I think the sorter plan is worth trying because the alternative plan is a complete design of belt-driven cluster of small containers, from ground up!
    The sorter can even be left upright (don't lay in horizontal) and the cut pieces can be redirected to enter from its side (some modification on the bins may be necessary).
    In your post for the Toshiba sorter, you said "on the board there are two push buttons, one to make the bins go up and one to go down". Is it common on most sorters? It would be fairly easy to control the movement by hooking up wires to the buttons.
    Since a second hand sorter (or a copier with sorter) is inexpensive, it's not that difficult to try it out (if I know which brand/model to get).
    Looking forward to hearing your feedback!
    mingliu
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Thank you for the complement and for trying to help with your project.
Can a sorter be used ?
Let's see: it seems that you are planning on modifying it to fit your needs.
-changing the bins to container type.
-moving them horizontally
The bins in the sorter are on two cams on each side of the machine that are syncronized.
each bin has a protruding pin on each side that goes into the cams to move it up and down.
sorters were made for vertical movement, to take apart and lay it horizontal.............................
I'm having a difficult time seeing the way you would do all of these without having to re-design the whole system.
as for the electrical part I'm sure if you have the schematics you could by pass and make a board to simulate the signals you need to make it work.
The idea is good, but unless you are willing to re-engineer the whole thing I can't see how it would be more beneficial to you.
Give me a feedback and we'll explore more options.
TNX
Posted on Feb 04, 2008
  • CheckitRight
    CheckitRight Feb 04, 2008
    Yes, most sorters have a dip switch and a set of push buttons on the sorter board, for the service mode.
    But, the sorters are still attached to the copiers, just apart. there is constant communication between the sorter and copier to "see" what state it's in, which is why you need to adjust the dip switches, ( Canon & Toshiba ) the two I'm more familiar with do have them.
    If you do buy a copier or/and sorter you must get the "service book and hand book" which gives you the all the electrical and mechanical functions.
    Before you buy take off the metal plate that hides the board, look at it, there should be a 4-8 pin dip switch. and two push button switches.
How to fix document feeder on HP Officejet Pro 8500A Plus
Might be a paper size issue, dirt on a paper sensor or drive rollers need a clean.
Mar 16, 2016 | HP OfficeJet Office Equipment & Supplies
Giving error place doc.feeder in the down position
problem with the feeder sensor >>top at the arrow
May 07, 2011 | Toshiba estudio 305 Copier
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
69 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
