Sony KV-27TW75 Black and White Picture
When I turn on the TV it will have a color picture but after a few seconds it will go to a black and white picture. I either turn the TV off and on several times or cycle through the inputs to get the color back. Once the TV warms up the color picture stays.
  • Anonymous Nov 27, 2008
    I have the same problem, but I don't understand your solution. Would it be easier if I just changed the coaxial cable? I have a different tv than the one in the original problem. Mine is: Panasonic CRT type, manuf. date 2003, has a combo VHS tape player.
  • Anonymous Mar 25, 2014
    The color was working just fine a few seconds ago and then it suddenly went to black and white. I just got this tv a month ago. Whats wrong?
    President:
  • 4,402 Answers
This is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Posted on Feb 04, 2008
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
My TV's picture constantly turns black and white then blinks back to full color. The full process lasts about two seconds and repeats constantly.
I have not repaired this particular TV. But my guess is you have some bad solder grounds on this aging TV. I would certainly inspect all your grounds on the CRT board and the main board. I would take a look at the color crystal. This crystal is a small silver box with two legs and may be next to the jungle IC. This two legged crystal in some cases have had bad grounds. Try this, and see what happens. Thanks for asking and show a few hands of support!
Dec 25, 2010 | Sony KV-32FS12 32" TV
The screen will show a white line every few seconds, then will black out, this will go on as long as the TV is plugged in.
The Picture Tube of the TV must have got damaged. Give the TV to TV brand's technical support and change the picture tube, Thank You.
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Sony TV KV 27FS 100 Picture in BW when connected to my Laptop.
connect a dvd to the tv using the same cable.
If the color is O.K. then the fault is in the laptop.
Thanks Guy9
Jul 07, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
2001 sony wega 36" tv tube
If you turn the color all the way off the picture should have good black and white if not the crt is at fault. If it is good it could be the jungle ic or the possibly the red color driver in the crt board
Apr 06, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV colour problem
how did you explain trouble do you have a problem on tv with color
board ,surely a capacitor has few' capacity' for making the driving on
color that can  be rarely
delfo
Dec 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Televison & Video Logo
377 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
