Can the feeder work without a copier
I don't know a lot about the technical details about the copy machine although I'm an electrical engineer trying to build a product sorter. So here comes my question:
The project is a automatic cutting and sorting machine. A continues strip of material is fed through an automatic cutter, which cuts it into sections in predetermined length (typically quarter inch by 3 inch). The piece then falls from the cutter and into one of 20 containers in a raw. Before the cutter makes the next cut, the containers are shifted by one unit-length such that the next piece will fall in to the next waiting container. The system repeats itself automatically and after each run the 20 containers will have one piece of material each.
A document sorter seems to me to be a good replacemnt to a custom made moving mechanism. If (1)the sorter can work/move horizontally without the existance of a copy machine and (2) there are simple ways (like hooking up two wires to a press button or providing a TTL signal) of letting the sorter moving 1 step at a time in either direction, I think this plan is feasible.
Is a typical sorter able to to that job? Or sorters from a certain brand can fit the bill?
Please let me know if more information is needed.
Thanks!
mingliu
  • 589 Answers
The problem you will run into is the size of the exited pieces of paper.
Most sorters / finishers use timing sensors (whether it be a timing wheel on lift motors, or photo sensors in paper paths) to determine when to shift positions, and most use separate control boards.
An older 10 / 20 bin sorter that uses gates may be the answer, but again, you will need to figure out how to setup the timing circuit so it knows when each piece exits.
These units will have to be modified to drop the exited pieces vertically in to waiting containers, instead or exiting horizontally onto trays. This may cause even more problems, as most of them rely on gravity itself to hold the exited paper on its feed belts / guides, and the entrance to the unit would then be on the top.
Another problem with this would be the overall size of these things. Remember these sorters / finishers are designed to hold quite a large amount of weight, and the units themselves can be quite heavy.
My best advice is to use something smaller, perhaps a sorting machine for mailing envelopes, or perhaps a modified coin counting device with a "barrel" type of distribution mechanism that you can modify with a slide chutes. If any more ideas come to mind, I will re-post them.
Good luck.
Posted on Feb 05, 2008
2 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: A question about the feeder
thank you for the complement and for trying to help with your project.
Can a sorter be used ?
Let's see: it seems that you are planning on modifying it to fit your needs.
-changing the bins to container type.
-moving them horizontally
The bins in the sorter are on two cams on each side of the machine that are syncronized.
each bin has a protruding pin on each side that goes into the cams to move it up and down.
sorters were made for vertical movement, to take apart and lay it horizontal.............................
I'm having a difficult time seeing the way you would do all of these without having to re-design the whole system.
as for the electrical part I'm sure if you have the schematics you could by pass and make a board to simulate the signals you need to make it work.
The idea is good, but unless you are willing to re-engineer the whole thing I can't see how it would be more beneficial to you.
Give me a feedback and we'll explore more options.
TNX
Posted on Feb 04, 2008
Line through copies
Check the scanner glass. Copier machine ussually has 2 glasses. The small one uses for the feeder, check it if you can find any material sticking on it and clean it with cotton cloth with glass cleaner solution. Please add also some details specially the model of your unit.
Nov 02, 2015 | Lanier Ld 425c With Df/print/scan/fax/4...
Tip
Copier Lingo, Jargon, Keywords Explained
When you're shopping for copiers you'll often see a bunch of acronyms or words that don't make any sense to you, the layman. That's what we industry insiders are for, to help translate these words and phrases into coherent thoughts. If you come across any copier lingo that isn't on this list, just contact me and I'll let you know what it means, then I'll add it to this page for future reference.
In alphabetical order:
  • ADF = Automatic document feeder. Every machine since the turn of the century has had one of these. There are variations of this term. See RADF and DHADF.
  • Bypass Tray = an additional paper source that normally supplies envelopes, labels, or heavier paper. It can be used to supply any paper that you don't have readily available in your regular paper trays
  • CPM = copies per minute
  • Developer = A finely ground metal material that adheres to the drum magnetically to transfer an image onto toner, which makes an image on your paper.
  • DHADF = Dual head automatic document feeder. Sometimes call scan squared, this feeder has two scanners that scan both sides of an original in one pass without flipping it around
  • Driver = A print driver is installed on your computer to communicate properly with your model of printer.
  • Drum = The drum is an essential part of the copy process because it "receives" the image from the developer and transfers it onto the paper with toner
  • Drum blade = The blade wipes the drum clean on each rotation. If you have an old drum blade you'll start to find lines on your prints.
  • Duplex = 2-sided printing, copying, or scanning
  • Finisher = An additional piece of hardware that enables the copier to staple and offset sort your printed documents
  • Fuser = The hot section of the copier that fuses the toner off of the drum onto the paper.
  • LCC = Large capacity cassette. This cassette will hold 3,000 or more sheets. It is an additional cost, hardware and adds to the footprint of the copier
  • Ledger Paper = 11 x 17 is commonly referred to as ledger, although it's more often just called "11 x 17"
  • Legal Paper = 8 ½ x 14 paper is commonly referred to as legal
  • Letter Paper = 8 ½ x 11 paper is commonly referred to as letter
  • MFC = Multifunction copier. Implies that it prints and scans along with copying.
  • MFP = Multifunction printer. Most "copiers" nowadays are MFPs.
  • PPM = pages per minute, a modern day variation of CPM since it implies more than just copies
  • RADF = Reversing automatic document feeder. This feeder will automatically flip an original to make a two-sided copy.
  • Saddle Stitch = Another form of finisher that will fold and staple documents like a booklet
  • Sorter = Another term for finisher. It will offset sort your documents and some manufacturers have a stapling function.
  • Toner = Toner is the "ink" of laser printers. It's a VERY fine powder that moves like a liquid, use caution when replacing your toner cartridge. Most toner cartridges nowadays have no open holes for toner to leak, but you should still be careful when handling one.
This should be a big help if this is your first time shopping for the correct copier for your office. If you have found this page you're probably in the process of shopping for a copier, so why not Request a Quote from me while you're at it?! I reside in Houston where I provide free delivery and installation of anything I sell, and I work with network of Sharp dealers all over the USA to get you what you need and have it installed by a professional. Don't delay!
on Feb 09, 2015 | Sharp Office Equipment & Supplies
There is a black line on the printed copy when doing a copy from the top feeder. There is no line when doing a copy from the glass.
The main cause for this issue is that there may be debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Please click on the link provided below for a more detailed instruction on how to correct the problem.
http://bitly.com/nyI8ts
If you need further assistance please contact Lexmark Technical Support.
Aug 09, 2011 | Lexmark X364dw Fast, Wireless-ready...
I want to download technical support manual for canon np 6030 what should i do?
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Jun 18, 2010 | Canon NP 6035 Copier
Auto feeder not working
Easy fix. Turn the machine off, on the back side of the document feeder is one beige cable. Unscrew the two screws and disconnect the cable. Turn the machine on with the feeder unplugged, let it come to ready. turn the machine off, connect the beige connector and turn the machine back on, It basically forgot it has a feeder and needs to plug and play without the feeder then to detect it when plugged back in,
Aug 13, 2009 | Xerox CopyCentre C20 Black and White...
F-5 error
Manual says F5 as copy lamp lightning abnormality.
Never had on AR series Sharp machines this trouble,but remember on old Canon NP 6016 when lamp was bad -no dark ends and low intensity of lightning but intensity too high.This machine was equiped with doc feeder and customer performed a lot of copies from glass only and I think he was damaged lamp when close the doc feeder.
the fluorescent type lamp was used on this Canon-Sharp uses Xenon lamp (I think),but they could be very common in construction (tube with electrodes on ends and gass inside)
This fault is very difficult to troubleshoot-try another lamp first,next sensor from good working machine.
Nov 13, 2008 | Sharp AL-1540CS All-In-One Laser Printer
TNX
Feb 04, 2008 | Toshiba 2060 Copier
Auto feeder misalignment
Are you sure you don't have a static problem locking the paper to the glass.
Mar 29, 2007 | Sharp AL 1631 Copier
93 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
