Question about Lite On LVW-5005 DVD Recorder
Doesn't recognize disks anymore
My LVW-5005X no longer will recognize that I have a disk inserted.
It will open and close with no problem, but always reports NO DISK.
I have tried already written DVD disks, blank DVD-R and DVD+R disks,
and blank CDs.
The unit has worked until now, but I had trouble with the door opening so I had to open the cover and remove the burner so I could get to the manual eject lever. Now it opens/closes with no complaint, but somehow it no longer recognizes there are disks in the unit.
I HAVE THE SAME PROBLEM ,IT DOESNT RECOGNIZE ANY DISK PUT INTO IT, IT REPORTS NO DISK, PLEASE HELP, ON MY LVW5005 RECORDER.
  • 1 more comment
  • MALLOX Feb 09, 2008
    THE SHW-160PS WOULD PROBABLY SOLVE MY PROBLEMS WITH MY LVW-5005 RECORDER BUT,WHERE CAN I FIND ONE IN 2008, I HAVE LOOKED IN ALL THE SUGGESTED PLACES,FROM THIS SITE,HELP! MALLOX
  • MALLOX Feb 28, 2008
    WELL I FINALLY FOUND A LITEON SHW-160P6S TO INSTALL IN MY LITEON LVW-5005, IT NOW PLAYS AND RECORDS ALL THE FORMATS BUT ONE, IT WILL NOT PLAY ANY COMMERCIAL BOUGHT MOVIES, HELP WHATS THE CURE. THE MALLOX
    I HAVE TRYED LENS CLEANING, IT DIDNT HELP, IF I TRY THE FIRMWARE UPDATE, SHOULD I TRY THE UPDATE FOR THE 160P6S OR THE FIRMWARE UPDATE THE PLAYER/RECORDER LITEON LVW-5005. THE MALLOX
  • 2,322 Answers
Check here for some more info.
If any of the above do not work, is more likely that the laser that reads the info from the DVD is not working and will need to be replace.
Good Luck.
Posted on Feb 28, 2008
  • Jaime Hernandez Feb 28, 2008
    I would suggest try the one for the LVW-5005.
  • 796 Answers
Try to clean the lens head
    Genius:
  • 3,422 Answers
I want u to go to the the below two sites and read the whole thing out carefully it will solve ur problem..
Click here
Click here
Goodluck,
please don't forget to rate me as fixya..
Posted on Feb 04, 2008
  • Priya darshan Feb 09, 2008
    Even i have looked for the manual but it is not released on the net yet
    Master:
    Sergeant:
  • 440 Answers
I would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Sony vx-515 dvd tray won't open
Mine was a Sony TS-P532 DVD in a Model GX315 player. A BLU-RAY disk got inserted and won't eject. Remove the player cover and on top of the drive is a 3 X 3 (approx) metal plate with a plastic wheel visible in it. Un clip the two sides of the metal plate and it will pivot up and the disk can be removed.
Mar 26, 2014 | Lite On LVW-5005X DVD Recorder
Manual for LVW-5005X CD/DVD need copy Have the Player need manual to hook up to TV
The user's manual is available from Lite-On as a .zip file. http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153 Select Audio/Video and then your model number in the two drop down menus; then click Search.
The direct link is http://www.liteonit.com/DOWNLOADS/DC/LVW-5005X/user_manual/en_us/LVW-5005X_US_English.zip .
You will need to unzip the file to read the document. With Windows, right click on the file after downloading and select "Extract All".
I hope this helps.
Apr 30, 2011 | Computers & Internet
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
The eject button on my VRDMC5 DVD recorder does not work at all.
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Apr 24, 2017 | Sony VRD-MC5 DVD Recorder
Unreadable disk error
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
Mar 14, 2008 | Lite On LVW-5101 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
After formatting the disk, it reads that it is an invalid disk.
I have a Liteon LVW-1107. It is a very tempramental machine. It tends to prefer +R or +RW disks. Will record on -Rs but may fail with them.
On occasion when I insert a store bought DVD movie I will get an
invalid disk warning. The machine seems to get confused.
What I do is pull the power cord and let it set a few minutes.
Give it a little time to reset. Sometimes you have to do this a couple times. It has always worked for me. I hope it will work for you.
Good luck. This is not a top of the line machine.
Jan 09, 2008 | Lite On LVW-1107HC1 DVD Recorder
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Dec 29, 2007 | Lite On LVW-5005 DVD Recorder
No Response To Open Button on Remote
I had the same problem- the door would not open.
I opened up the unit removed the drive and discovered a lever which allows to manually eject the tray. After playing with this a bit, I discovered that if I hit open on the until and depress this lever, it would open reliably. Not ideal, but at least it gives me ability to open/close.
Unfortunately once I put the unit back together, it no longer recognizes any disks. I must have damaged some disk sensor mechanism in the process. On the bright side however, it open/closes reliably now, doesnt even require the lever to be depressed manually. So if I can just get it to recogize disks, I am in good shape again.
You may not need to open up the unit and remove the CD burner to get to the manual lever, but you have to remove the fancy cover plate for the tray to be able to access the lever. The cover plate on mine is silvered and says "All write". The lever is on the underside of the tray to the left side, a paperclip might be able to poke thru to access it without removing the whole front cover.
Good luck.
Dec 27, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
164 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
