Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Horizantal Lines and Poor Picture Quality
I have about 6 or 7 horizontal lines going across my tv and the picture quality is horrible, especially on the color white and other bright colors. It looks almost like sand...that's that best way I can describe it. I've had it for 13 months now and, of course my warranty was only for the first 12. Has anyone else had this problem? I called circuit city, where I purchased it and they said that it will cost $99 for a terchnician to come to the house, then additional costs for labor and parts. I'm hoping that there is a simple solution...maybe just a clean or something. Any advice would be greatly appreciated!
  • Wukusick Feb 05, 2008
    They don't flicker, but sometimes you can't see them as well ie: if most of the colors on the screen are dark, then they're not as noticeable as if they were, let's say white. A new thing that I noticed last night though...now I have a new horizontal line that moves very slowly from bottom to top. Once it gets to the top another one comes up from the bottom and goes to the top, and so on.
  • George
    George May 11, 2010
    CAn you please send me an digital image of the problem you are having?
    George,
The only thing that I have hooked up is a Playstation 3, but yeah they are still there...not as bad as when I'm watching cable, but they are there.
Posted on Feb 11, 2008
    President:
  • 4,402 Answers
Do they flicker on and off?
Posted on Feb 04, 2008
  • Cary Farah
    Cary Farah Feb 06, 2008
    are they there if you use a dvd or vcr?
Picture quality
Contact your local service rep as this sounds like a "not so easy fix' related to the main board or power supply (known issues with Mits boards, especially the capacitors). Cleaning, resetting, re-configuring will not likely make any difference. Verify the problem occurs across all input modes (such as DVD, etc). before taking any service actions.
Jun 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
Poor picture quality
You need to consider the following tips herein as follow:
1) Field collapse (horizontal white line on screen)
R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
2) Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Please let me know any update
Nov 29, 2007 | Toshiba 27AF42 27" TV
Toshiba 32AF42 Poor picture quality
TRY ADJUSTING THE SCREEN CONTROL ADJUSTMENT AT THE BOTTOM OF THE FLYBACK TRANSFORMER.THIS SHOULD REMOVE THE RETRACE LINES AND ANJUST THE HASY LOOK TO THE PICTURE IF NOT YOU HAVE A BAD CAP IN THE SCREEN CIRCUIT .LOOK FOR A 10MFD/250V CAP IF FEEDS THE NECK BOARD ATTACHED TO THE PICTURE TUBE 200V DC.
Jun 22, 2007 | Toshiba 32AF42 32" TV
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
