Question about GE 74801 Clock Radio
Resetting clock I need to know how to reset clock
  • 8 more comments
  • Anonymous Feb 07, 2008
    LaCrosse Technology WS-8117U-IT-C my clock is 2 hours fast. I set it and it keeps going back to 2 hours fast?
  • lboogie2324 Feb 19, 2008
    How to reset the clock
  • eboo Mar 09, 2008
    can't reset to daylight savings
  • inverness Mar 23, 2008
    I CANNOT RESET THE CLOCK. PRESSING THE + OR - BUTTONS UNDER THE WORD "TIME" DOES NOT HELP. I ALSO CANNOT CHANGE THE MINUTES. TONY
  • LouToYou Apr 16, 2008
    I can't re-set the Timex T301B to the proper time zone even after trying all 7 zones. My clock doesn't seem to allow for DST in the Pacific NW. Please find a solution.
  • nhjohn Aug 25, 2008
    how do i set the time
  • Anonymous Nov 02, 2008
    can't reset clock
  • joycnathan Nov 02, 2008
    need to reset time
  • jslocumb72 Nov 03, 2008
    i need to know how to change the time on my clock.
  • metry1209 Dec 26, 2008
    i cannot set the time nor alarm - please help!!
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
Posted on Nov 07, 2008
I've just realized that it seems complicated because we are used to seeing the numbers flash to indicate that we can change them; however, with this clock, it does not work that way.
Also, you do not need to hold the SET button down.
To set the CLOCK ...
Press SET three (3) times ... it will display the wrong time and the colon will flash - just press the FF or RR to set the time and you can press and hold down FF or RR to move ahead or back faster. Then press SET to store the new time. And you are done!
To set the ALARMS ...
Press SET once ... it will display wake 1 time and just press the FF or RR to set the time. Press either CANCEL once or SET 3 times to exit.
Press SET twice ... it will display wake 2 time and just press the FF or RR to set the time. Press either CANCEL once or SET 2 times to exit.
Enjoy your clock!
Posted on Sep 23, 2009
LouToYou adds:
To set your clock back 1 hour you must click the time change (up or down buttons) 60 times -- which is one hour.
EXAMPLE: The clock does not change from 3:46 to 2:46 without you pressing the Minutes button 60 times after the time started flashing. The minutes will change the hour to the next lower hour after you have "deducted" a full 60 minutes. Or, the minutes will increase the hour to the next higher hour if you add 60 minutes to your pre-set time. You add or deduct minutes to change the pre-set hour.
Posted on Apr 29, 2008
From LouToYou regarding the Timex T301B clock/radio/alarm: I wrote an email to the Timex company and they wrote back saying:
We apologize but there is no patch available. Consumers must change clocks.
Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times.
Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
So, manually hold down the Time Set button until the time flashes (this takes some time -- mess around with it). Then use the up and down arrows just above the Time Set button to set the the clock to the correct time. Be sure to have the correct time zone set first. Hey, it worked for me!!!
How can i change the time on my bose awrcci, the time change i dont know how set up
Posted on Feb 04, 2008
I found a solution to my Bose no feature for time adjustment: I wake up "earlier" one hour! This way, I am not in late for work for 1 hr! I wish they could have send the instructions with the machine...especially since they are not quite easy to replace financially speaking...
3 Suggested Answers
SOURCE: lost manual for Nexxtech motion clock. Need to reset
Try and look up the instructions on the internet. That may help a little.
Posted on Dec 29, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
Posted on Jan 15, 2009
How do you reset the time on the clock ?
I would need to know exact name and model of your controller?
Nov 06, 2017 | The Audio Players & Recorders
I want to know how to reset my clock in my 2005 Honda inspire car. the dash is all set out in Japanese.
Don't know your car but clock on a lot of cars is controlled by the other button near the odo reset - press and hold till clock flashes, these buttons are normally near speedo and rev counter normally ignition on engine off then sometimes your button turns left or right to adjust. Either that or search for images of your car and it's clock.
Jan 01, 2015 | Honda Cars & Trucks
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
Time Zone one hour ahead
What make and model clock?
Apr 18, 2013 | Audio Players & Recorders
How to troubleshoot a mother board
to trouble shoot motherboard you need to know basic of motherboard there are mainly three thing s for motherboard to work first voltage +12v +5v +3.3v the motherboard then needs clock and reset to start adreesing the lcok is produced by the 14.318Mhz crystel and restet is produced by 32 khz crystel when the power is on first the clock has to be present for the reset to function if the clock and reset and there and the adress line is not still working means the elecrolitic capcitors are fult the capacitors in motherboard have huge role to play they are ones prvent audiolines entering the adress lines
Jan 29, 2011 | ASUS M2N-MX Motherboard
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Easy one...93 Lincoln...need to know how to set the clock on the radio/cassette as well as the stations. Thanks in advance!
assuming this is the digital clock, you hit the clock button on the dash, followed by the reset button followed by the clock button. at this point, you should be able to hit the clock button to advance numbers, and the reset button to change the numbers you are setting. if its the analog clock, pull on the knob and turn it
Nov 01, 2009 | 1993 Lincoln Town Car
Lost manual for Nexxtech motion clock. Need to reset
You did not supply a model number and the Nexxtech web site has no information, however, I did track down the supplier, Orbyx
Just enter the info model number etc. and see what comes up.
This is the maker of the Clock.
http://orbyxelectronics.com./manuals.asp?choice1=3&choice2=4&hidPickIndex=2
Dec 18, 2008 | Emerson CKW2000 Clock Radio
Clock will not reset
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Your owner's manual will you tell you what the icons in the display mean.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Once you've done a reset and checked your manual, if you still need help, let us know.
Dec 11, 2008 | Microwave Ovens
GE 74801 Clock Radio Logo
3,087 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
