Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
Cannot connect wireless to internet
I connected my zyxel modem to my pc via ethenet. but when i try running on wireless only, on the last page of setup i get a window that tells me my isp cannot be connected to at this time try later. Iget on orange signals either. the modem i have P66- Hwt. My reason for buying this product is to run a laptop.
  • 22 Answers
Sounds like either you aren't really connected to your router, or there could be a software error. One other thing is wireless interfernce. Check the IP address of your laptop after you connect wirelessly. If it not somthing like 192.168.x.x or whatever your router assigns, if there is a differnt one from that, it is most likely interference wrong connection or bad router. Messege me on aim @ copter64.
Posted on Feb 05, 2008
  • Christopher Sibiski Feb 07, 2008
    Opps, i read that a little to fast, have you try to clone the mac address yet for the pc connected that was to the modem, if not do that then release and refresh the WAN DHCP
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
ZyXEL P-330W wireless router
No it will not work you cannot connect a router to another router wirelessly and it will most likely not be detecting each other, routers are built to transmit internet signals from modems if you have a router and a computer but you do not have your own internet connection that will not work conencting to another router you will need USB Wifi Card transmitter/reciever to be able to connect to your friends wireless internet.
but if your friend only has a modem you can lend him your router and get a USB wifi transmitter/reciever to be able to connect to your router that is conencted to your friends modem this will work but will not work if you and you friend will both have a router creating a network.
Jun 20, 2010 | Zyxel Prestige P-330W Wireless Router...
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
I have just installed a brand new HP Pavilion running with Windows Vista Home Premium. I'm already running a Windows XP Home edition wireless with no problems connecting the internet.. The new HP is...
I assumed you've restarted the router. I only ask as I often have issues like that where some units can see the internet and some can't when freshly connected. The other thing is to check that the adaptor settings for the network card under ipv4 dont have any manual DNS settings and is set to auto unless you are using a public DNS such as Google and then the override settings such as 8.8.8.8 and 8.8.4.4 would be fine.
Jul 17, 2017 | Zyxel Prestige 660HW Wireless Router...
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
ZyXEL adsl wirless modem router P660HW
To bring up the blue screen you need to open internet explorer (or whatever) and type the ip address given. In my book it says 192.168.1.1 after that you should get the blue screen. You can set up the connection then.
Jan 08, 2008 | Zyxel P660HW-D1 Router
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
119 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
