Question about JVC TH-A35 System
No surround through S/PDIF
I hooked up my system to my pc through S/PDIF it's digital and should send through all channels, but in stead it reads on display as a stereo source and I'm not getting any surround channels. PLEASE HELP
  • jansenonline Feb 05, 2008
    maybe I wasn't clear, I connected my pc to the surround system using an optical wire, the soundcard I just bought, a creative soundblaster X-Fi Gamer also has an optical S/PDIF port, so what should I add?? Thanks in advance
    Problem Solver:
  • 7 Answers
The problem is that your system does not support surround via S/PDIF. It detects it as a regular stereo jack. You could always add a digital out to your PC such as Optical or Coax Digital.
Posted on Feb 04, 2008
6ya staff
SOURCE:
What does RF out mean and spdif mean. Plz
RF out means Radio Frequency output. That will send out video and usually audio to a compatible device like a TV. For example connecting a VCR or older games console was done with the RF out on the VCR or console sending the picture and sound to the TV.
S/PDIF is a Sony /Philips Digital Interface Format.
It is a means of sending sound from one device to another. For example from a Blu-Ray player to a surround sound system. This is usually done with a Toslink lead that uses light to send the information but apparently it can use RCA leads, I've never seen that.
May 06, 2016 | Computers & Internet
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Vst system link errors
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
Oct 28, 2009 | Audio Players & Recorders
Would like help with hook up wiring
i can not find the sound driver of my notebook NT-R45 can you help me pls
Jun 03, 2009 | Sabrent SBT-USB51 External Sound System
I have a x-540 speaker system I brought today. Do I need a sound card to make it work with my pc. I hook it up/no sound.
A stereo computer system with resources to produce and record surround sound channels. Such surround sound channels are played or recorded using an audio card added to the computer system, which audio card controls additional speakers and/or microphones. Software for redirecting instructions from existing stereo application programs and sending these instructions to the existing audio device driver and the additional audio device driver is needed. Resources for processing the digital audio data for either extracting surround sound channels from two channel data provided by the application, or for encoding two sets of two channel audio data recorded by the two audio cards is also needed
Dec 02, 2008 | Logitech X-540 Multimedia Surround Sound...
Sony STR de845, 5.1 Surround does not work. 3.2 is indicated o
3.2 IS the "5.1" mode for this receiver. 3.2 is indicating that you have 3 front channels and 2 rear channels. The ".1" is applied to all the speakers (LFE). If you read the manual on page 37, you'll see that "3.2" is displayed with either "Dolby Digital 3.2" or "DTS 3.2". The little icons of the speakers in the display window will show you which channels are active. The bottom line is as long as you see the blue light, it's decoding multi-channel discreet surround sound (at least 5.1).
Nov 22, 2008 | Sony STR-DE845 Receiver
Can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Nov 06, 2008 | JVC SXXSW6000 Speaker
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Surround cuts out???
Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
Mar 05, 2007 | RCA RT2280 System
JVC TH-A35 System Logo
216 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
