Question about Yamaha RX-V2600 Receiver
Back speaker sound
I have one speaker connected as a back left speaker. I get sound from it when I select 7ch audio, but never hear anything from it when listening to a movie with Dolby Digital or any other selection. Appreciate any suggestions.
  • 3 Answers
One rear channel is common. its called 6.1
Posted on Aug 02, 2009
    President:
  • Yamaha Master
  • 1,114 Answers
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Posted on Jun 06, 2009
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I cannot hear ANYTHING. The speakers are plugged in and properly inserted into the computer but i still cannot hear anything
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 11, 2011 | Kinyo PS-107 Computer Speakers
I just sold my surround sound system and now I can't get the on board speakers to work.
Just check the rear of the television if by chance you have left any cable still connected to the audio output jack. If there the TV might be trying to redirect the audio to an external device not present. Sometimes it could also be a simple setting to be changed , . Check if you have a switch at the back of the TV stating External or Internal speakers. From the manual i got
A/V Receiver: The TV can detect audio connections on the DIGITAL AUDIO OUT jack and the right (red) analog AVR AUDIO OUTPUT jack.
Note for Analog A/V Receivers: When you disconnect an analog A/V receiver, manually change the Speakers setting to TV to hear sound from the TV speakers.
Press Menu on the remote-> Goto AV
Select Audio by pressing the right key
Under that the first option of Speakers -> select and set to TV.
Only then will the TV speakers play the audio.
Hope this Helps.
Mar 04, 2011 | Mitsubishi Televison & Video
Why is my left speaker coming out with no sound, but my right speaker (no controls on it) is working? To note, when I move the cord that plugs into the sound source, I hear crackling in the left speaker...
is the cord you move laying on a rug or carpet this will cause static
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 23, 2011 | Juster AC-691 Computer Speakers
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
Im not sure if its the computer or the speakers but i cant hear anything?and there on and look fine,just cant hear anything?
Make sure the speaker connection is connected in back of the cpu. Check device manager to see that the audio and all hardware is working properly. Open up sound from the control panel classic view sound to see if sound is working. Just a couple of ideas.
Nov 30, 2009 | Dell Dimension 4700 PC Desktop
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Yamaha RX-V2600 Receiver Logo
185 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
