Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Can't do anything
When I plugged it in to the USB cable the SanDisk c250 went to Lock and I can't do anything. Please tell me what I can do.
  • cobra dick Feb 04, 2008
    I have the same problem with my c250 2GB. I use it everyday and today it just stopped working. Only light is the blue light around the center button and has no display.
    Is this one of these forums where users complain and the support people only read the entries to get solutions from the users and not the engineers?
I left the player on all night until it ran out of power the next morning. It was at that time I pluged the USB cable to the unit and recharged it from my laptop.
I checked the "Hold" switch several times and it was not engaged when I noticed the problem. What ever the problem was allowing the unit to completely drain itself of power and then recharging it solved my problem.
Posted on Feb 08, 2008
  • 758 Answers
It sounds the the hold switch is on..The Sansa c250 Hold Switch is located on the side of the device, and is used to prevent any accidental
operation. Once the Hold Switch is moved to the lock position, all function keys will be disabled.
Buttons on the Sansa c250 will not operate when the Hold Switch is active.
  • Jean Sintulaire Feb 08, 2008
    When you say that you plugged it on the USB to the device, do you have the device connected to the computer? and if so it should say connected.. meaning that the device is charging...during that time you cannot do anything on the device itself..when you unplug the device from the computer does it show the lock or does it say connected?
6ya staff
SOURCE:
Unlock never used player
Is the orange color above the Lock switch visible on the left side of the player ? Then it is in Lock position (factory set to Lock).
To unlock: Switch the Lock switch upwards (orange color not visible).
Next before first use, charge the player for 3.5 hours on a computer
with the provided USB cable.
Jul 13, 2010 | SanDisk Sansa e250 MP3 Player
I had music on my sansa cant find it and now it said memeroy is full and i know it not
hi its because of virus in ur system so try 2 formate ur card for better result else install anti virus in ur system
Aug 24, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa clip 2 gb
My sandisk c250 will not charge on my laptop do I need software or can I download a program.When I plug in the mp3 it will not do anything.
Sep 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk c250
mp3 players do not need software if you are using xp or vista.
JUST Connect it to your computer uing a USB cable and itwill be shown as a rremovable drive. Just copy and paste files to your player thats all!
Apr 16, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa E200
Hi what you need to do is get the battery flat so the mp3 player is off then plug into charger nut leave it off then follow these instructions
1. with player off switch the lock button to lock
2. with key lock still on press and hold down rec button on left hand side
3. whilst still holding rec button down switch on still holding rec button down.
4. now the screen should say recovery mode dont press anything
5 goto sandisk website and download latest firmware for your device.
6. once downloaded onto computer select the programme on your computer
7. it will then take you through the process of reinstalling the latest firmware for your mp3 player.
After doing this you should have no problems but if you do then give me a shout back then i can help you further ok
Mar 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Invalid image on sansa c250
hold the record button
plug in the usb jack
release the record button
this should put it in the right mode.
then you need to reinstall the correct firmware.
since sansa doesnt post this on their website, check out the anythingbutipod forums
Feb 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Unable to download anything SanDisk c250
In order for you to resolve the problem you are having, you will have to update the firmware on the device...This is a common problem whenever the device firmware is corrupted...To download the device firmware you need to go to site below....
http://sandisk.com/Retail/Default.aspx?CatID=1376
And also you need to check the device USB mode under setting...It has to be under MTP mode or auto...should you need any other assistance please contact me or you can call call sandisk1.gif at 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Feb 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My c250 turns on, but not in the way I would like it.
Try a hard RESET by holding the POWER and the MENU for about 15 to 20 seconds. That may reset the player back to the factory settings.
Jan 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 not working at all!
2 Suggestions: 1) It may be that the battery isnt charged, let the unit charge fully 2) If that doesnt work, its probably time to send the unit back to sandisk
Jul 23, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
