Question about RCA RTD120 System
Setting up the surround sound
I can't get to the menu to start the setup. What am I doing wrong?
  • hard ass Apr 13, 2008
    how do i hook up my rtd120
  • daynor Jun 25, 2008
    Changed batteries in remote--now, remote will not turn on--put both batteries in positive side up?? Help!!
    Scholar:
  • 103 Answers
Make sure the TV is 'looking' at the right input. If your system is connected to A/V input 1, then make sure the TV is set to that input. If everything is ok there, pressing MENU should bring it up. It's easiest if there is nothing in the DVD player.
You can also download the manual from RCA's site. CLick the link below to get it.
http://support.rca.com/main.html?pagetypeid=6&topicid=307&selectedmodel=RTD120&navtypeid=2&selectedFamily=video&prevPageIndex=2
Hope this helps, and please rate my advice, good OR bad.
Good luck!!
Posted on Feb 05, 2008
Can't get the subwoofer to work
try setting the front speakers to 'small' in the setup menu. some models of pioneer receivers disable the subwoofer output if the fronts are set to large
Feb 18, 2015 | Pioneer Vsx-d457 A/v Receiver-5.1...
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I bought this recover and so far everything works but for some reason I cant get any surround sound from the recover running hdmi from blue ray player on the display it shows sw, LF, RF that's all I can...
hi,
you reseiver is now in stereo mod that's why there is no surround and center. its some thing related to to the setting in the receiver or in the blue ray.
Settings in blue ray player
First of all check the audio settings in your blue ray players audio setting.
You didn't mentioned the brand of your blue ray player. Anyway go to its setup and set the audio output priority as HDMI. also turn OFF the DRC if its a sony blue ray player. Also check the down mixing setting make it satandard
Settings in receiver.
First of all check the surround settings.
Play a blue ray disk and press the STANDARD button o the receiver's remote and select STANDARD mode.
If you didn't get the surround channels follow the below procedure
Now go to the setup of your receiver.
1. Using the down arrow go to the Advanced play back and press enter.
2. In the Advanced playback menu select auto surround mode and press enter
3. Select it ON using right arrow or left arrow. and press enter
4. Exit the setup and check is every thing working fine.
If dosn't work
Again go to the setup of the receiver
1. Using down arrow select Speaker setup and press enter
2. In the speaker setup menu select speaker configuration and press enter
3. Check the status of all the speaker, if any speaker is in NONE position , make it LARGE or SMALL according to the speaker you are using.
Exit setup and check again.
If you need any more assistance feel free to contact me through fixya.
regards
Ajin
Feb 05, 2011 | Denon AVR-3806 Receiver
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
Aug 14, 2009 | Yamaha RX-V463 Receiver
Surround speakers are not working
Yes. Make sure your speakers are first properly connected, then enabled to operate on the setup menu. Then run either a test tone for all channels or media recorded in surround sound or run in 4 channel stereo to test.
Not all media will produce surround effects 100% of the time.
Jun 18, 2009 | Denon AVR-3300 Receiver
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Dec 22, 2008 | Yamaha HTR-5830 Receiver
RCA RTD120 System Logo
131 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
