Question about GE Spacemaker JVM1640SJ Microwave Oven
BREAKING MICROWAVE SAFE DISHES
MY BRAND NEW SPACEMAKER IS CAUSING MY MICROWAVE SAFE DISHES TO GET HOT TO THE TOUCH AND BREAK COMPLETELY IN HALF WHILE COOKING. THIS IS MY SECOND SPACEMAKER AND I'VE HAD THE DISHES A FEW YEARS WITH NO INCIDENT. WHAT'S GOING ON?? THANKS FOR ANY HELP!
  • mackinnon_k Feb 11, 2008
    It's true that the problem does not occur with a lower setting but I have to heat the food longer. I'm concerned that there may be a problem with the microwave as I've used the same microwave safe dishes for a couple of years in my last Spacemaker. I realize that microwaves may vary but ........ I've never had it happen before.
    Thank you for your input!!
    K
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Have you tried running the unit at a lower power setting?
  • 492 Answers
I would recommend having it looked at. Sounds like the magnetron or the maser is malfunctioning and not operating within it limits which could be potentially dangerous.
Posted on Mar 11, 2008
GE Spacemaker shorting
From your description the cooling fan is not running, causes! open motor winding, seized motor, or defective door switch, you will need somebody to assess
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker SL 1800 arching
Get some warm soapy water and clean inside making sure there are no food particals, if no change! the magnetron may be breaking down.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hello, I have a GE Spacemaker 2.0 (JVM2070SK) and with an electronic touch panel. The unit is 3 years old, the panel lights up with all the options however, when you touch the screen nothing happens. Then...
This is a common problem, and they're often intermittent.
You'll need a new touch screen.
You can get complete details on all these 2070-series microwaves on my page here:
http://www.microwavecontrol.com/jvm2070.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 01, 2017 | GE Profile Spacemaker Over-the-Range...
Oven will not heat but turnstyle and other features operate ok.Is there a fuse that can be replaced?
several of the GEs i have worked on with your symtoms turned out to be bad magnetrons ... if the magnetron gets too hot then it will go bad .. you can get it really hot by running it without anything in the oven .. but several of the failures were caused by a fan mount failure ... there is a fan that cools the magnetron .. it is mounted on a plastic framework .. if the plastic breaks or distorts then the fan is not aimed in the correct direction .. the air goes around the magnetron instead of thru it and it fails to cool the magnetron ... so in these cases the fan framework was repaired and a new magnetron installed .. often that repair costs more than a new microwave oven .. there are other things that will cause the same trouble .. a high voltage diode, a capacitor, a transformer, a relay and a high temperature cut out switch ... the cutout automatically resets once things cool down but it can go bad .. the cost of some of these things is not high but labor often dictates the repair vs replace decision ... magnetrons cost a lot unless you have connections .. .at any rate you dont want to be powerering the microwave when its taken apart .. with the cover off there is potentially fatal voltage and current avalible by just touching the wrong thing .. ..
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Main board
Not likely it's the touch buttons wearing out you can buy the tocuh pad and replace it it's not that expensive, go to www.appliancepros.com and find your model and look at the parts list and find your part, they have a break down of the parts assembly.
Nov 12, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
How to replace the door handle on Spacemaker built in Microwave
take a small flat edge and pop out the plastic trim on the inside of the door, you will have to pry a bit but it will pop out, be very ccareful as it will break quite easily,,,,, the back of the handle is now accessable
two screws
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hello
you would need to take the door apart. however by doing that you will cause more damage than just lettin it be unsightly. if the mw is 5 yrs or older wait for it to break and get a new one
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
120 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
