Jenn-Air JMC8130DD 1000 Watts Microwave Oven
Problem for Jenn-Air JMC8130DD 1000 Watts Microwave Oven
Gas electric with convection oven ( 48600)
By judithbraun on Feb 04, 2008
I'm having a problem getting the oven to self clean. Its been a while since I used this option. I went through the steps, put the time in and it shows timed clean but the door doesn't lock and cleaning doesn't start it just goes back to showing time
Solution #1
posted on Jan 04, 2009
Not Rated)
freetek
Rank: Wiz
Rating: 85%, 1846 votes
Old message but maybe you are still living with the problem.
There are safety switches that must close with the oven door before  the cleaning cycle will initiate and one or more of these may have failed. Sometimes these are actuated by metal tabs on the oven door that fit into slots on the mating surface. If yours is so constructed, use a popsicle stick or similar non-conductive probe and poke it into each slot listening carefully for a quiet 'click' or a change in resistance to your insertion. If one of these sounds or feels different than the other, one of them is probably bad although finding an action doesn't guarantee that the switch is electrically functioning. Unfortunately, if your oven is constructed as described, the switches are only accessible by removing the side panels from the range.
The door lock feature is a must since the self-clean temperature must reach 900+ degrees to enable the catalytic action to occur.
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JMC8130DD 1000 Watts
Questions and Unsolved Problems for Jenn-Air JMC8130DD 1000 Watts
Do you recommend Jenn-Air JMC8130DD 1000 Watts Microwave Oven?
Answer
Answer
Why does the top and side of my microwave, Galanz Model #P60D17L-D5. get so hot? Is it supposed too?... (More)
Answer
how to set power levelto 1000 in the Jenn-air microwave
Answer
by turning on the light comes up the sound of running is not coming nor it is warming up
Answer
Everytime we turn on the air here a smell comes like something is burning but we dont turn on the... (More)
Answer
How do I get to the fuse on a Jenn-Air Microwave oven Model JMC1830DD
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
