Question about Kitchen Appliances - Others
Siemens porsche kettle om switch problem
When I press the red on switch it doesn't switch the kettle on. It used to "click" but now it doesn't . It was an expensive kettle so I'm loathed to buy a new one if this can be repaired. Can it? Could I repair it myself?
  • 1 more comment
  • achenstrasse Feb 16, 2008
    Really helpful, thanks. Amazing thing is that it's sorted itself out! I now works again. I think the switch must have stuck. I was on holiday for 5 weeks & usually the kettle is used about 6 times a day so may be not using it for 5 weeks was the problem.
    Your comments are much appreciated.
  • catelyn Apr 14, 2008
    flama-the on/off button won't engage!
  • Anonymous Mar 15, 2014
    will i need to cnage the plug to a standard one and if so whcih fuse do i need to use
  • 552 Answers
Some switches are called momentary and others are the click on and click off type.
It could be a problem with the switch if is is the click on type.
It could be a relay that "seals in" when you press the on off switch to on.
By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay.
If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle.
I don't know by the information, if this is a household small appliance or commercial?
Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
Posted on Feb 09, 2008
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ... > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ... > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Does the Siemens Euroset 805 have a high low volume switch ?
Thanks M.Qasim for the solution!
Just a small correction you have to set the phone while is ringing. I did the following sequence call to the pone then press "Set" "#" "4" "#"
Oct 28, 2012 | Siemens Euroset 2005 Corded Phone
Kettle doesn't heat up and no light comes on when press the On button
Check the obvious, 13amp fuse, if intact connect a multimeter switched to ohms across the live and nuetral pins of the plug (not plugged into mains) the reading should be between 0.05 ohms and 1.5 ohms if higher the element has burnned out or the over temperature sensor has activated. to determine which you will need to open up the bottom of the kettle and expose the wiring. using the above multimeter with the same settings locate the heating element this will have two terminals protruding from the water compartment thes will have eithe screw or spade connections, connect the multimeter across these two terminals and check for the readings above if correct the problem is the over temperature sensor if not then the problem is the heating element. the over temperature sensor will be a circular disk with two terminals clamped to the underside of the water compartment.
Aug 27, 2009 | Bosch TWK-9110UC F.A. Porsche Water Kettle...
How do you adjust the clock on a porsche cayenne s 2005
Hi, British Summer time hey! You can use the indicator stalk to access to menu.
Navigate your way to settings, the select the Clock option and set the time using the ricker switch, you can also format the clock to 12 /24 hour - enjoy!
Apr 14, 2009 | 2005 Porsche Cayenne
Siemens porsche kettle on/off switch problem
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
1,231 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
